JD 40 1953 hydraulic pump
boler76
12-09-2007 14:40:22
What do you restorers do to renew your hydraulic pump so it will build pressure again? Is there an aftermarket pump , has someone started manufacturing rebuild kits ? I would really like to get mine back to good working condition again, Thanks Jim
buck eye al
12-10-2007 14:44:49
 Re: JD 40 1953 hydraulic pump in reply to boler76, 12-09-2007 14:40:22
Sometimes the problem with a 40's hydraulics is the suction line. It goes up to the very top of the hood right along the steering shaft & if it has rusted through, the pump can suck so much air they just won't work worth a hoot. They also won't leak if the hole is way up on top because as soon as you shut it off, what oil it did pull out of the reservior runs back drawing in more air. Hints that this is happening (at least for us on our 40W) were chattering, frothy oil and air venting out of the filler opening as it ran, especially when cold.
Have read where putting a couple or three pounds of air into the system via the filler cap when it's warm but not running makes such leaks show up pretty easily. May take a while but if it's a leakin, oil will start runnin & such low pressures won't hurt anything. If you go too high on the pressure, you can pop the rock shaft seals out but if they're like ours were, that would be hard to do. They too were leaking pretty stoutly! I just took ours all apart & put in new seals fixing leaks all the way. Works great now & don't have the ever rising crank case oil problem any more.
Later.
Dave H
12-10-2007 06:01:23
Jim
If you think it is not performing good enough I would think you would have to open it up and have a look. The oil is gear driven and like stted the basic parts should be available. The affordability of the bearings from deere surprised me.
Reason I would take it apart first is to see if the gears have cut into the housing - that would be bad doo doo.
hapy holidays.
Mike M
12-09-2007 17:51:33
If just seals and bearings JD likely can fix you up. If you need more like housings and gears than check with JD first.have them run it on the dealer locator and if they don't have any or if they want more than the tractors worth you are just going to have to search for another used pump and hope it is better than what you have.
boler76
12-10-2007 14:45:46
 Re: JD 40 1953 hydraulic pump in reply to Mike M, 12-09-2007 17:51:33
I have had the pump apart and the seals and bearings are good but the gear to housing clearance is where the problem is. I guess buying another old pump is an option but how do you know if it isnt as bad or worse? No new parts available I am told by deer dealer and also hydraulic shop, just thought some one might know of an aftermarket setup Thanks Jim
jd40an
12-10-2007 15:31:49
 Re: JD 40 1953 hydraulic pump in reply to boler76, 12-10-2007 14:45:46
I haven't needed to do anything to my 40U since I installed new seal & shaft many yrs ago to stop hyd oil from getting into the crankcase. I did tighten up the clearances on a live pump that mounts between the governor housing & Mag/ Dist on "ABG" tractors. I took it to my local machine shop (where I formerly worked part time)& used his surface grinder to reface the side plates. I then placed both gears & the spacer on the magnetic chuck & refaced first one side & then the other. The last step was to remove the center housing (spacer)& grind another .002 off the gears for clearance. This worked very well & that pump is still in service after at least 15 yrs. I don't see why this wouldn't work just as well with your "40"s pump.
boler76
12-11-2007 03:30:00
 Re: JD 40 1953 hydraulic pump in reply to jd40an, 12-10-2007 15:31:49
Thanks for the info on resurfacing the pump parts, I have done something similar with grinding compound and a piece of glass to get the side clearance between gears and pump body down to specs but the clearance between the teeth and the centre body is were the problem lies as far as I can figure and the only solution I see is new gears and new centre body, Comments please Thanks Jim
Mike M
12-11-2007 04:22:52
 Re: JD 40 1953 hydraulic pump in reply to boler76, 12-11-2007 03:30:00
Your just going to have to find a good used one. Call around to the various used vendors in green magazine and so forth. See if any are willing to take the pump apart and stick a feeler gauge in it before shipping it or if they will return it if it doesn't meet satisfaction.
