 Regan, electrical options (lights and starter) were made available for the model �H� as a mid-year model change (1941 model year) commencing with serial number 27000. Prior to S/N 27000, the end cap (�dash� as some would call it) was outfitted with two holes, one for the temperature gauge, and one for the oil pressure gauge. Subsequently, the tooling for the end cap was modified, and a third (center) hole intended to accept an ammeter was provided. However, since electrics were always optional items for the model �H�, many tractors after 27000 were furnished without generators, ammeters, starters, etc. Accordingly, the center hole for the ammeter was partially punched through similar to a �knock-out� found in electrical enclosures. The idea was for the knock-out to be removed to permit mounting of the ammeter. Similarly, small-diameter knock-outs were provided for the light switch and for the choke knob. (The choke knob was provided only for those tractors outfitted with starters.) The picture is shows this arrangement. (This picture shows a non-stock choke control through the actual choke control hole.) So, if your serial number is earlier than 27000, there should be no provision for an ammeter. If you have a later tractor with no evidence of electrics, and if you have a hole in your end cap, it is possible that someone swapped your end cap with one from a tractor equipped with electrics. Of course, there�s always the possibility that some time in the past a little gremlin decided to poke your knockout out of the end cap, just because they could.
