'36 B Block Crack
Kris A NC
12-09-2007 09:12:17
OK guys here we go again. I got the block out today and I noticed a crack on the very bottom skirt of the block on #2 cylinder. I would like to know what you think my options are. I know a replacement block is always an option, but is there a chance to repair this one, or does it need repair since it is so far down? I am sure it does need some sort of repair, but I thought I would throw that out there. Thanks for all the help so far. You guys have been great. The second picture may be a little hard to see, but it does down to where the sleeve meets the block and then makes a 90* turn to the left.
third party image
third party image
Thanks
Kris A NC
DickD
12-11-2007 06:38:05
 Re: '36 B Block Crack in reply to Kris A NC, 12-09-2007 09:12:17
Kris; I don't know what you are planning on doing with your tractor, but if you arent planning on using it for long days with a hard pull, I would say, from looking at the location of the crack, it is repairable. Like Frank, I think the Muggy weld is the way to go, but unless you have SOME experience,I would have it done by someone who has. Sleeving is probably the best, but around here is costly.
Josh B
12-10-2007 11:56:41
I second that for the muggy weld anyone can do it. Definetly worth the money.
jd b puller
12-09-2007 18:55:30
Kris, where at in NC are you, I"m a little south of Raleigh.
The bottom picture, opposite the crack, the bore looks funny in there. Might just be the way it came out in the picture, but looks "scuffed". Not crazy about the way the crack is trying to run around the cylinder either. I"d want to look that thing over pretty close, but I"d probably bore it out, then put a replacement sleeve in there. As for your pistons, you"ll need to measure the piston at the skirt to determine wear.
Kris A NC
12-10-2007 03:43:15
 Re: '36 B Block Crack in reply to jd b puller, 12-09-2007 18:55:30
The "scuffing" you see is just from the oil that is drying in the cylinder wall. I am in charlotte.
KRis A NC
Mike M
12-09-2007 12:37:09
You can have a machine shop sleeve it.
Kris A NC
12-09-2007 14:35:55
 Re: '36 B Block Crack in reply to Mike M, 12-09-2007 12:37:09
Mike, If I sleeve it, do I have to get different pistons? The ones that came from it are the original and to be honest there is not a lot of ware. Looking for a wear ridge...I can"t find one on the #1 cylinder and only a very hint of one on #2. I might just need to take it to a shop and have them braze it. I took your guys" advice before...I will not attempt brazing. Thanks Mike
Kris A NC
Mike M
12-09-2007 17:45:11
 Re: '36 B Block Crack in reply to Kris A NC, 12-09-2007 14:35:55
They can make it any bore size needed for your pistons. Feeling for a ridge won't always tell the whole story because what if someone before you removed the ridge ? Only one way to determine bore wear and that is to measure it. Use either an inside mic,telescope gauge and outside mic or bore gauge.
old
12-09-2007 12:08:11
Again not a job for a novice to braze. Take it to a good machine shop and they can probably fix that or know if it can be fixed
Rob in UPrMI
12-09-2007 11:17:43
I have a good block from a 1937 B that I would sell, if you wanted to go that way. I don't know if they are the same or not. If interested email me at [email protected] and we will talk
Hoss in Maine
12-09-2007 09:20:27
As compression is not an issue here I would grind the crack from the outside maybe halfway through and braze it up just to keep it from falling apart.Hone it some after welding. It wont hinder performance and only you will know about it.Later Hoss
teddy52food
12-09-2007 12:07:03
 Re: '36 B Block Crack in reply to Hoss in Maine, 12-09-2007 09:20:27
Grind it and braze it & it will be ok for another 50 years.
F-I-T
12-09-2007 19:28:23
 Re: '36 B Block Crack in reply to teddy52food, 12-09-2007 12:07:03
If you are going to try and repair it, I want to pout in a vote for a welding rod for cast iron that even a novice like me can use to get good results. Do an Internet search for Muggy weld. I am impressed every time that I use the stuff.
Frank
