Don't know the first part of the conversation, nor what you're brazing. On brazing I use the acetylene torch with either the air nozzle/tip which uses ambient oxygen sucked in through the nozzle, or the regular oxy/acet rig with the brazing tip. The way I braze is to get the receiver material cherry red (orange) with the blue tip of the flame and with the appropriate brazing rod (brass/steel/silver solder) dipped in flux, start feeding the tip of the rod onto the surface(s) right at the flame (blue) tip. Give it time for the rod to get hot. Feed in as much material as you want/think you need and move along, repeating the process. Main thing I learned in brazing is that your materials need to be as clean and shiny as possible as oxidation/contamination interferes with the process, and use a good appropriate flux for the job, and don't be stingy with it. If your receiver material is too cold and your melted rod is rough looking and piled up, just add more heat, using the blue tip in direct contact with the rod material (already deposited) and adjacent material till the weld melts and makes a nice smooth joint. It's just like soldering. A tad more flux (no more rod, just dip the rod and when the flame melts the flux melts on your weld, remove the rod). Easiest brazing material to use is the brass and works fine for a lot of applications. If welding thin steel sheet, like a tailpipe to a muffler, I use coathanger wire, or similar gauge steel rod. Silver solder is a heavy duty brazing compound which works good on refrigeration copper tubing. Lastly, the smaller the flame the easier it is to control the process and make a nice joint; course, the flame needs to be large enough to heat the surface to be brazed. Mark
