DLTX10 Carb
Krkdeere
12-09-2007 05:45:18
I have a dltx10 carb and need to know if it is possible to replace the ball and spring that hold the adjustment screws for load and idle in place, Mine seem to be froze up and in to far so they dont hold the needles. Thanks Ken
Duane Larson
12-09-2007 08:33:52
 Re: DLTX10 Carb in reply to Krkdeere, 12-09-2007 05:45:18
Ken,
When I run into this problem, I take some rust-buster (Kroil, W-80, ...) and a small punch and hammer. Soak the area around the ball and start tapping on the ball with the punch. Just tap lightly, you will probably push the ball down somewhat but you don't want to drive it too far. Keep spraying and tapping and soaking - most of the time the spring will take over and they will come loose.
One problem which arises if the ball and spring must be replaced is cracking and breaking of the casting during the staking process to retain the ball. If that happens, one can use a spring plunger kit - I use one from Vlier - it is a ball and spring in a tube - just drill the old ball and spring hole a bit larger and push the Vlier unit in place - works fine but does not look exactly original.
John T
12-09-2007 06:34:40
Yep its possible, one has to get the old ones out of course and then sort of peen/punch the casting to hold the new ones in. Dont ask me more then that cuz thats about alllll I can tell ya
John T
old
12-09-2007 08:50:14
 Re: DLTX10 Carb in reply to John T, 12-09-2007 06:34:40
John, did you see my post from yesterdy on what I found out that tractor was??
John T
12-09-2007 09:39:47
 Re: DLTX10 Carb in reply to old, 12-09-2007 08:50:14
I must of missed that?????
What board n where???
JT
old
12-09-2007 09:44:45
 Re: DLTX10 Carb in reply to John T, 12-09-2007 09:39:47
This board, (JD) Heading is got a call from a guy part 2. Any how the tractor is a 1935 model D. Its in ruff shape but I hope to be able to get it and bring it back to life. Engines locked up, steering it locked up as is most of the levers etc. No tires and or what is there are so bad they can't be called tires any more. Let my wife see some pictures of what a D looks like and she said I'll have to keep it if I get it so she can drive it in the tractor parades
John T
12-09-2007 11:58:56
 Re: DLTX10 Carb in reply to old, 12-09-2007 09:44:45
Gee Rich, youre a glutton for punishment lol. Breathin life back to an old stuck D may drive you to drink, sounds like a tough one but its our hobby of choice so best wishes and were here to help, but Im not much of a D man so dont expect much from me
JT
old
12-09-2007 12:05:23
 Re: DLTX10 Carb in reply to John T, 12-09-2007 11:58:56
Ya I figure getting it back up and running might take a lot of time and a lot of tranny fluid to boot. But if nothing else I might at least save one from the scrap man even if I find its to far gone to do more then just part it out.
