1951 b won't start
cylinder
12-08-2007 17:47:29
trying to restore 1951 B lapped the valves installed new new rings. has not been started in over 20 years, cleaned carb. when turing over it back fires thru the carb. timing looks good. where do I start. thanks for any and all help. Dave
cylinder
12-09-2007 13:47:11
 Re: 1951 b won't start in reply to cylinder, 12-08-2007 17:47:29
Thanks to the both of you the JD 1951 is running Thanks again Mr. Old & Mr. Andy M I have been fighting this for over a week and you guys solved it less them a second. Thanks again. Now that it is started the oil pressure reading is just coming off the needle in the gauge, can you send me in the right diretion to start solving this problem.
Andy Motteberg
12-08-2007 21:08:10
Like old said, try switching the plug wires. If that does not work, check the plugs and carburetor adjustment.
old
12-08-2007 18:12:55
Switch the plug wires around and see what happens. If that doesn't work recheck the valve gaps and make sure you have them set right. Also make sure you have a good gas flow and that the carb isn't set to lean
