3020 battery charger hookup
Ken M
12-08-2007 14:53:45
I recently got a 3020 Diesel 24 volt tractor. My question is, how do I connect a charger. If I hook up to one battery pos to pos and neg to neg does it charge the other battery correctly or backwards when using a 12 volt charger. Do I need to disconnect and charge one at a time? I'm not much for electricty.
John T
12-08-2007 15:34:32
 Re: 3020 battery charger hookup in reply to Ken M, 12-08-2007 14:53:45
NO, you dont need to disconnect them to charge either one of them one at a time.....
YES, if you have a 12 volt charger, you have to charge them one at a time, + Charger to + of Battery and - of Charger to - of Battery.... then you charge the other battery
If you had a 24 volt charger like the 24 volt generator on the tractor, then you could charge them both at once in series.
One of the batteries has its - tied to frame ground and the other has its + tied to frame ground which is how the lights are still 12 volts, some on one battery + ground and others on the other battery - ground buttttt ttt the 2 outermost untied battery posts (+ on one battery -on other) is how the series 24 votls is derived for the 2 wire frame ground isolated devices like the staretr n charging system.
get it????? ??
John T
55 50
12-10-2007 08:15:48
 Re: 3020 battery charger hookup in reply to John T, 12-08-2007 15:34:32
John, I'm gonna tease a little here. In the last sentence how about "frame-ground-isolated devices"? (add the dashes?) I had to slow my reading speed down a bit there to see what you were saying, lol. Thanks for your always great inputs. Another retired EE. Ron
Ken M
12-09-2007 10:20:33
Thanks John. I appreciate the information that you always give.
buickanddeere
12-09-2007 10:44:40
 Re: 3020 battery charger hookup in reply to Ken M, 12-09-2007 10:20:33
Is the right side battery going dead?
