Crack in DLTX10 Carb
Kris A NC
12-08-2007 14:33:11
I have a small crack in the throttle shaft housing of my dltx10 carb. I am just curious what some of you guys might try to fix it. I know I have heard of some great ideas on other fixes from you guys so I thought I would try and give this a whirl. Thanks and I appreciate all your suggestions.
third party image
third party image
Andy Motteberg
12-08-2007 21:09:45
 Re: Crack in DLTX10 Carb in reply to Kris A NC, 12-08-2007 14:33:11
It does not look that bad, a little JB weld should be good enough.
Duane Larson
12-08-2007 17:29:52
Kris,
When I run into that problem, if the crack is "serious", I groove it and braze it back, (although brazing isn't all that great under tension). Then I carefully ream a SMALL amount out of the cast hole for the bushing so it still requires some light driving to put it in place, and use a good sleeve retainer (eg, NAPA 765-1149) on the bushing before putting it in place. Sometimes I only do the reaming and sleeve retainer.
The alignment of the two bushing holes must be retained, the bushing must be snug enough to be reamed to fit the throttle shaft without turning, and the casting should not crack when the throttle shaft bushing is installed.
Mike M
12-08-2007 17:19:43
2 options ? Grind it out and braze it in and the you will have to machine it. Or use somekinda gas proof sealer like JB Weld or permatex #1 smear some in there and on the bushing and then drive the bushing in. This should stop any seepages. This is one I'd do as that isn't a crucial crack.
