830 2CYL BLOWING OIL
GTHING
12-08-2007 08:56:17
Hello all I recently purchased a 830 electric start that had been parked for about 5 years in the dry barn.I put new batteries in it and fresh fuel and it fired right up.I ran it for a couple hours on and off not constant.I started it one day and let idle for about 40 minutes and it began to belch oil out the stack.It did not do this prior or did it have evidence of it ever did. I pulled the injectors and pumps and had them gone through.The shop said that they saw nothing that would cause my complaint.My question is where do I turn now start tearing the head off or should i try to hook it to my 5 bottom plows and work it?
Rich Duane
12-09-2007 14:59:56
 Re: 830 2CYL BLOWING OIL in reply to GTHING, 12-08-2007 08:56:17
Have you changed the oil aand filter. Sometime the condensate formed from setting boils and makes alot of vapor out of the vent.
MSM
12-08-2007 23:33:40
Are you sure it isn't condensation. When the condensation mixes with the old soot,it gives an oily appearance. Make sure the thermostat is good and the engine is getting up to temperature. Letting them sit and idle isn't real good for them,if you must do it speed it up to 1/2 throttle. Like was said below,taking it out and working it hard will do it a world of good. Just change oil and filter before you do.
Ron in N.E. Colo
12-08-2007 14:40:14
Before you begin a teardown, you might check a few things. Was the crankcase oil level OK? you might make certain it didn't seep diesel into the crankcase and fill the crankcase. There is also a crankcase breather with a small oilcup on it. I bought a 730 diesel several months ago which did the same thing. I cleaned the oil cup on the breather and it stopped the slobbering. For some reason, 2 cylinder diesels which have sat for a few years will do this. Hope this helps.
skip33652
12-08-2007 14:37:02
first things first decide what exactly what you want from this ol girl. If you want it perfect pull it apart and rebuild it.. then you will know what it is you have.if by god no way in H I am going to spend $3000 overhauling it quit worring about it and enjoy. if you are really curious do a compression test as well as leakdown and find what is the problem or problems.
I bought my 820 on a 10 degree day it fired right up and sounded good when I got it home and started messing with it I found a leaking exhaust valveso i pulled the head off and thought well maybe I will slip in some bearings and make the pony stop smoking before i was done I had a reground crank, a reground cam,new valves guides and seats, and rings runs like a top. another story is a buddies 80. it started missing one day after having used it in hay field for 5-6 years. I put in new rocker arm and fired right up but Carl said it just doesnt feel right. I thought it run and started fine but had some blow by.when I tore it down the bottom half of one piston was laying in the bottom of crankcase as well as three broken rings and a bent rod. I guess it set up and then they pulled it around to free it up. anyhow to make a long story short they run pretty good even when they are not in good shape at all.Paul
GTHING
12-08-2007 10:15:23
Thanks for the information I was afraid that I was going to get involved in a tear down.I did put the injectors back in yesterday and let it run for a half hour 3/4 throttle and the oil just would slobber down the manifold from the muffler to manifold joint.What is the possibility that if I work the old horse I might free up a stuck ring if thats what it maybe.I just cant believe that I did not have this problem then all of a sudden it showed up.I would think that if it had been doing this previously the tractor would have been caked with oil build up.
F-I-T
12-09-2007 07:19:11
 Re: 830 2CYL BLOWING OIL in reply to GTHING, 12-08-2007 10:15:23
Is it smoking when this slobbering occurs? Typically, slobbering comes from a worn out engine. I hear the folks that say just work it hard and it will go away, but that has not been my experience. If it is worn out enough to have excessive blow-by, it will stay worn out unless repaired. When I re-bore a block, install a pair of new pistons, have the pumps overhauled and the injector calibrated and synchronized on the rack, even if I only run it a few hours on the engine per year, it never slobbers or smokes. I can take my old 70D out of the shed today, warm it up, and throw it on my dyno at full output and it won't slobber at any speed. It probably won;t hurt it to run on a load in case you get lucky and old rings loosen up, but I would not hold out much hope in that regard. Wear an old shirt as you will get the fabled "Diesel Slobber Measles".
Maybe remove the oil filler cap and see if that additional venting keeps the crankcase pressure at a point where the oil doesn;t want to push into the combustion chamber.
Since you had the valve cover off, I'm sure you checked to be sure that the oil returns were clear. Oil can enter through the valve guides if the oil gets trapped in the valve cover. As was mentioned, if you have a leaking fuel transfer pump, diesel could be diluting the crankcase oil as the fuel gets by bad seals.
Also, if you decide to go through the engine, pay attention to the valve guides and to the wrist pin bushings. A lot of people skip those items and the guides will aallow it to continue use some oil and the wrist pin bushings can be really noisy, and you don't need any more noise when it comes to that engine.
Frank
draw
12-08-2007 09:26:56
Are you sure it was oil and not unburned diesel? Idling any diesel for that period of time (especially if the engine is not warm enough or is starting have some wear) will cause it to slobber from unburned fuel.
wilamayb
12-08-2007 09:18:45
Hooking it to that plow at heavy load will make it smoke like a coal buring train for about 15 minutes. It will then clean up a bit. After you let it sit and idle for 40 more minutes you'll be back in the same boat. It more than likley needs the works (block bore, new pistons and rings, bearings, valves and seats. These old diesels are often found in this state, because they just keep running and running and running even when worn out. They will continue to run for hours and hours even the the condition of yours.
You may help your situation some by making sure it has a working thermostat. Keeping them at operating temp will help to keep the oil burned out of the combustion chamber. That of course just converts the ooze to smoke...
Rest asssured yours is not the only one with this problem. I'd be willing to bet that half of the diesels out there have this problem. Most folks hate the throw the $3000 or more dollars it takes to freshen the engine.
