JD 2755 Hydraulics
Cliff Huxster
12-07-2007 20:06:50
I have a 2755 turbo that I have now lost the 3-point hydraulics and I have no power steering but my PTO is fine. It was working fine one minute and then it quit. It doesn't matter what RPM I run it at. Any suggestions?
R. John Johnson
12-08-2007 05:13:39
 Re: JD 2755 Hydraulics in reply to Cliff Huxster, 12-07-2007 20:06:50
I'll second the splines stripping out on the pump coupler shaft. I've had to replace several on our 2755. When they go, you suddenly lose all hydraulic functions.
John
LarrySTN
12-07-2007 21:59:01
First look to see if the hydraulic pump shaft in front of the engine is turning, sometimes the internal splines in the pump coupler wear out. More likely though, a tube has come apart inside the transmission.
