Best heater to buy
Lekander883
12-07-2007 14:13:55
Which is a better way too heat up an engine to prolong its life on cold winter starts. Either engine block ( lower radiater hose type ) or magnetic oil pan type. All info appreciated. Gasser 1020
mmidlam
12-07-2007 16:11:04
 Re: Best heater to buy in reply to Lekander883, 12-07-2007 14:13:55
the lower hose type will only work if the block is higher than the radiator so that heat can flow uphill into the block.
LenND
12-07-2007 19:07:20
 Re: Best heater to buy in reply to mmidlam, 12-07-2007 16:11:04
If you put a hose heater in the lower hose the radiator can be any length it won't make any difference. Ive put in a few of them and they work as good as a regular tank heater. Unless you tank heater is of higher wattage.
F-I-T
12-07-2007 15:40:26
I had one for a VW Rabbit diesel years ago that was a heater hose type, and what was neat about it was that it had a trap valve in it so that a nit of fluid would be trapped and get so hot as to approach the point of a boil, then percolate out the other end, so it circulated the coolant. It did a nice job, though it was a pretty small 4 cylinder engine. I think it actually came form the local Western Auto store.
We also had the tank-type JD brand heater on the 4020 and it did a good job, and that was a much larger mass of cast iron.
buickanddeere
12-07-2007 15:20:11
Lower rad hose is a good idea, only problem is they heat the rad more than the engine. The magnetic units can be used along with common sense to warm crankcase oil. A low wattage block heater threaded into a frost plug is best for standby applications. Avoid high wattage units as the weenie little heating element with with high watts tend to burn out. The tank heater is the hands down winner for quick warm ups. Deere sells 0W-40 synthetic motor oil which helps. Get the hydraulic pump de-stroker, what a difference.
Mike M
12-07-2007 14:48:08
Get one of those little tank shaped type heaters and plumb it into the block. JD should maybe even still have a kit for those. The magnetic ones are a joke and thought I have heard a fire hazzard ?
