JD #35 loader on 430
Hayfarmer
12-06-2007 19:25:50
I have a #35 loader on a JD430, was put on by the dealership when both were new. It has the original Greasan valve on it. It was originally trip bucket but I added a second valve and bucket cylinders. The original valve has the normal input line from pressure line on pump, outlet or return from other side going to rear housing and a third line that domes off the bottom below the pressure relief valve and goes to the rear housing also. The parts book shows the 3rd line. Other valves I have seen have only pressure and return. Was this just the style of the valve? I can disconnect the 3rd line and the loader seems to work fine.
Dave H
12-07-2007 17:16:09
 Re: JD #35 loader on 430 in reply to Hayfarmer, 12-06-2007 19:25:50
My #35 is used on a late model '58 420 when mounted. I still have the trip bucket and will keep it that way. On the newer valves, they have to be open center and also have their own relief valve on them just like the old setup. Depending on what you mounted for the hyd bucket you might be able to get the same kind of valve and it will bolt up aside that one and you will be set to go. I know I can add more valves (spools) onto mine but that is just the way it came.
Mine runs off the same pump that is on the fromt of the motor that powers the touch o matic. It works fine for me.
Hayfarmer
12-07-2007 17:52:08
 Re: JD #35 loader on 430 in reply to Dave H, 12-07-2007 17:16:09
I seem to get lots of air into the system. I think it may be comeing from the old valve. The system has slowed down a lot and I think it may be leaking back through the relief. This tractor and loader were purchased new in about 1960 or 61 I think by my uncle. He had a chicken farm and moved a lot of manure with that tractor. I put new o rings in the front pump once but it has never been worked on otherwise and I suspect it may be getting a little weak. Will still put out about 1200 pounds pressure directly off the pressure hose. I think I may replace both valves with a single 2 spool valve.
Dave H
12-07-2007 05:23:59
Hayfarmer
As I foggily recall, you are probably disconnecting the return line from the pressure relief/bypass valve. I think that the old engineering deal on the original valves is that if you go into bypass the oil from the bypass has a separate hose for return. Newer valves like I put on my #35 have the oil routed internaly from the bypass to the one return.
So I think that disconnecting that one return that is for the pressure relief may put you into a situation where something will blow if the loader is loaded past the point of what it can handle. As i see it doing that would disable the pressure relief system on the antique setup.
Hayfarmer
12-07-2007 07:01:09
 Re: JD #35 loader on 430 in reply to Dave H, 12-07-2007 05:23:59
I believe you are right Dave. I am looking at putting a new valve setup on the #35. I am also getting air into the system and think it may be the old valve. The old pump has lots of time on it also as the prior owner, my uncle, used it all the time on a chicken farm. What tractor is your #35 on? I was thinking about going to a separate front mount pump.
