70 Diesel update#3
NW MO Poppers
12-06-2007 16:55:58
Ok, the switch was hooked up wrong, but when i switched the wires, still has power. The wire comming from the VR is hot all the time. So, does this mean that the VR is not wired correctly, or that the points are sticking, or both? The service manual is a little vague as to the proper wiring of the VR, and I didn"t hook it up the first time (a mistake I won"t make twice). It has a 6 volt positive ground VR, with three post on the "front", and a wire coming from the bottom that connects to the "armature" post, then looking AT the terminals, its white wire, black wire, then wire to the "field" post. I guessing that the two wires are reversed, but not sure. HELP!! Thank you in advance. Josh
Blksmok
12-07-2007 05:28:15
 Re: 70 Diesel update#3 in reply to NW MO Poppers, 12-06-2007 16:55:58
Josh....are the three posts coming off of the VR marked bat, gen and fld? The field post (F)of the generator hooks to the fld post of the VR. As you're facing the generator , it's the post farthest to the left. The armature (A) post of the generator hooks to the gen post of the VR (the center post) and is pigtailed with a wire running up to the ammeter. The wire hooking to the bat post of the VR (far right post)runs up to the fuel rocker switch.
NW MO Poppers
12-07-2007 09:25:54
 Re: 70 Diesel update#3 in reply to Blksmok, 12-07-2007 05:28:15
Thank you. I believe that two wires are hooked up backwards. Hopefully, this will fix it. I'd like to use it to blade some snow this afternoon.
Josh
