Gathering of the Green 24 volt seminar
Tom43
12-06-2007 15:30:01
Dear Forum,
In March I am conducting a seminar on the John Deere 24 volt system. I would appreciate hearing what problems you have encountered with this system. Years ago I had a 730 diesel that mysteriously started cranking while I was driving it. I don't know why it did this. If you have an explanation or any other horror stories please respond.
WTW
12-07-2007 07:46:10
 Re: Gathering of the Green 24 volt seminar in reply to Tom43, 12-06-2007 15:30:01
Tom, If the starter engaged by itself after it had been started and running, about the only thing that could cause this would be a short to ground in the engaging solenoid starter circuit. If solenoid circuit (between solenoid and starter push button) shorted to frame ground it will cause the 24 volt starter solenoid to engage on 12 volt. The 24 circuitry of these systems is totally isolated from frame ground. Every 24 volt function (Starting and Charging system) on tractor requires two lines isolated from frame ground. The frame of tractor is used for the individual 12 volt ground circuit/functions. If the any part of the energizing side of the staring circuit shorts to frame/ground the starter solenoid will engage on 12 volt. What is happening, the 24 volt starting system/circuit is connected/supplied live to one 12 volt side of the 24 volt system, when working normally when operator starts the tractor the opposite 12 volt polarity half of the 24 volt system is connected to starter to make the 24 volt isolated "series" starting circuit. To summarize, you probably had a short to ground in your starter ignition circuit. Good Luck, DW
machinery-man
12-07-2007 04:49:04
I guarantee you I'm no expert or not even knowledgable but did rewire the 730 E/S for the older friend. Recommend following...check Generator for output or cleanup or have rebuild. Get a NEW regulator, get new wiring(he got the kit from gentleman on G magazine) once all wired switches, starter button everything looked good EXCEPT one side of light dimmer than other. Got the old parts book and reviewed all wiring diagrams and found that a battery had to be ground as the whole circuit itself not grounded...zammmmm lights even output, everything worked perfect. I'd never try mismatching some old wiring, looks like you'd have a melt down or whatever....older friend was tickled with outcome...spend a little money but well worth it. The kit has some different ends on a couple of feeds and we had to change but minor in comparison to upgrade....my advise is to rewire....
John T
12-06-2007 19:18:19
Tom, Im glad youre giving it, they tried to talk me into it n I tried to get Glen to do it, I will be in the front row unless one of my seminars conflicts with your time slot.
Common problem is the copper dust off the starter brushes start shorting inside the starter to case frame n runs a battery down.
The connection to frame ground where the batteries series tie in the middle can go bad n the lights dont work.
Few understand the basics of the system
See if you can get Dave WTW or BuickNDeere or my friend Gerald J to offer some advice
John T (NOT certified over 12 volts lol)
buickanddeere
12-06-2007 20:21:27
 Re: Gathering of the Green 24 volt seminar in reply to John T, 12-06-2007 19:18:19
OJT
There still is the entire 24V system from one of the 840's kicking around here. Can't come up with a good excuse why I haven't wired up yet for a demo unit. I want to attend but between this year's events but..... .. my father probably not being able to attend, generating unit outage$ and maple syrup season. Odds are GOG isn't going to be in the cards for this year.
Mike M
12-06-2007 18:54:08
Those systems run on smoke and once the smoke gets out it doesn't work. LOL
55 50
12-06-2007 19:08:16
 Re: Gathering of the Green 24 volt seminar in reply to Mike M, 12-06-2007 18:54:08
I'm a retired EE and I know how they work but it's rather hard to put it into words for those who have little or no electrical knowledge. But I have no clue as to why one would start cranking while you were driving it. Maybe your knee bumped a switch and you weren't even aware of that. That's a "blue-sky" sheer guess!
