1940 JD A clutch question
Dean Lydey
12-06-2007 04:54:45
I've taken my repaint project of a '40 A to a fairly detailed level. Once you get into it I've found I'm nearly doing a nut and bolt restoration. Mechanically, the tractor is very sound. It was when I started, let's see if it is when I get it back together. I've taken a $1500 tractor that in Expo condition is a $2700 tractor and have proceeded to pour about $2000 into it. Brilliant huh? My time of course on top of this. I now understand why the rare tractor is where the smart guys concentrate. Oh well, my first attempt at a cosmetic resto. Anyway, I'm 95% complete with a clutch brake question. I've dissaassembled the clutch brake, fork bearing and fork shaft. These are found on page 21 in the parts catalog. The spline shaft on the fork shaft needs to be oriented properly in the fork. I didn't pay attention to this in the disassembly stage...my mistake. I was hoping a registration mark would help but there doesn't seem to be any. As I go to reassemble this orientation is important. Frankly, it's critical to make the clutch function properly. Any advice as to how to get this spline oriented in the fork correctly. Im concerned that I'll get close and be off a a single spline. Is there a way to hit it dead nuts on? Or can adjustment in the lever linkage makeup for this.
Thanks in advance,
Dean
Resting Relics 1
12-07-2007 06:09:49
 Re: 1940 JD A clutch question in reply to Dean Lydey, 12-06-2007 04:54:45
Hey Dean, We repair and rebuild these old tractors for the love of it mostly. Most of us in no way could justify the expense from a business standpoint. If you want to make money on these old tractors you'd be better off selling off as parts. It's a disease with me but bringing these old two cylinders back to life is a great hobbey. John
CalJim
12-06-2007 21:11:46
Yes 90 degrees. CalJim
Mike M
12-06-2007 05:40:32
Congradulations ! You join the rest of us who have put buckets full of money in a tractor. LOL
I'm not 100% positive,but I was thinking that fork to shaft relationship leaves the arm at 90* to the fork. Fork pointing back and arm pointing towards the gov. housing.
