49 A split pedistol???
58401
12-05-2007 19:19:36
I recently purchased a 49 A with rollamatic, will a wide front end bolt up? Does anyone know if the 49's came with split pedistols? I won't get the tractor home till next spring and I forgot to look. Thanks.
Andy Motteberg
12-05-2007 20:25:32
 Re: 49 A split pedistol??? in reply to 58401, 12-05-2007 19:19:36
The split pedistal was used on the John Deere AW and the AN. They are the "high clearance" versions of the "A". AW means "A Wide Front" and AN means "A Narrow". The AN uses a single 1 wheel front end. A two wheel front end was a option for the AW and AN.
4020LP
12-05-2007 20:03:42
Split pedestals became optional equipment on Model "A" Tractors beginning with serial number 648330. Prior to that serial number the only "A" series tractors with the split pedestal were the "AN" and "AW" Tractors. However, a kit was made available to convert the earlier tractors with the two-piece "split" pedestal.
J. Chantry
12-05-2007 19:39:53
I think it will. I have a 49 A with a wide front end. Looking at the parts manual, The pedestal (part#AA3920R) and steering spindle (#AA3922R) are the same for a rollomatic and a wide front end.
