MORE 44 B QUESTIONS
BUB
12-05-2007 17:20:43
THANKS FOR ALL THE ENCOURAGING WORDS GUYS I WAS WANDERING IF I GET IT UP TO TEMP IF I SWAPPED OVER TO KEROSENE IF I WOULD GET MORE POWER, OR WOULD I BE ABLE TO TELL ANY DIFFERENCE? I HAVE RUN IT ON KEROSENE BEFORE JUST DRIVING WITH THE SHUTTERS CLOSED AND IT RAN VERY GOOD. NOW WHEN I MEAN THIS THING IS WORKING I MEAN IT IS REALLY DOING SOME TALKING JUST WANTED YOU ALL TO KNOW THE LOAD THE ENGINE IS UNDER BUT IT RUNS STEADY AS A ROCK.AS I SAID BEFORE I RUN IT LIKE THIS FOR AN HOUR OR MORE AT TIME. LOVE THIS JOHN DEERE STUFF.
Ken Hansen
12-07-2007 09:42:51
 Re: MORE 44 B QUESTIONS in reply to BUB, 12-05-2007 17:20:43
We use #1 fuel oil in our old all fuel John Deeres. LOTS cheeper than kerosene and works fine.
Mike M
12-06-2007 05:52:08
The only thing you will notice is the smell of the exhaust and likely need to readjust the carb.
THE SMOOTHED DEERES
12-06-2007 06:18:00
 Re: MORE 44 B QUESTIONS in reply to Mike M, 12-06-2007 05:52:08
And a lighter wallet from buying that kerosene ...
James Howell
12-06-2007 08:55:19
 Re: MORE 44 B QUESTIONS in reply to THE SMOOTHED DEERES, 12-06-2007 06:18:00
This week while in Tractor Supply I saw a 5 gallon can of Kerosene priced over $35.00!
Lord Help Us!
almrm
12-06-2007 07:03:47
In Michigan, Kerosine cost less than gasoline. I noticed last week as I was filling up my diesel pickup that Kero was $3.14 at the next pump over. Gasoline was $3.32 at the same station. Diesel was $3.59 GRRR. The Kero was red dyed and prohibited for road use but that should be fine for a tractor. Since then, gas has come down to $2.96 and I do not know if kerosine followed suit. If the above cost differences are consistent, running the all fuellers on kerosine would be a way to aviod road tax for fuel for the farm without having to keep a bulk diesel tank on hand.
Mark
THE SMOOTHED DEERES
12-06-2007 07:12:37
 Re: MORE 44 B QUESTIONS in reply to almrm, 12-06-2007 07:03:47
Kero here was 3.52 and gas has been under 3.00 for awile .
almrm
12-06-2007 07:32:54
 Re: MORE 44 B QUESTIONS in reply to THE SMOOTHED DEERES, 12-06-2007 07:12:37
On second thought, it is likely that some stations like the one I was at do not keep their kero prices current due to low usage. They might just change the price when they have the tank refilled based on their cost instead of market swings.
I have one all fuel tractor and I do not run it hard enough to use kero. I would like to hear one working hard on low octane fuel sometime.
Mark
Will P
12-05-2007 20:07:10
How much HP does this hammer mill need? My 43B that has .045 over cast iron kerosene pistons, all fuel manifold and the all fuel carb on it makes 21 HP out the PTO. She is about as stock as you can get.
Enjoy!!!
Will
GeorgiaHayFarmer
12-05-2007 17:58:12
Bub,
You could swap it over to kero one day and see what kind of difference that makes. I'm sure it will be noticable but would be interesting none the less. You must have an all fuel manifold on that tractor so you will be able to work it fine on kero at the rpm your running it at. It would be interesting to see what the temperature does after an hour or so.
Scott
