G/MAN: Moving Rear Wheels on 4020
Nellie 47
12-05-2007 14:18:42
Back in July I read your post on this forum about moving rear wheels that are stuck. I printed that information out and kept it in my file. I just got around to working on the tractor again last week. I've followed your suggestions but as of yet no luck. I have been rapping on the axel with a 2# sledge. Should I get out the 10# sledge and give it all I have? I have been hitting the axel next to the hub as I assumed thats what you mean't. The pinion is also stuck. I have been using PB blaster on the pinion and also on the axel where there is a 1/4" gap between the wedge halves. I have been keeping pressure on the forcing wedge screws. I'm using a 3/4" drive socket with a 2 ft. pipe. I haven't given it all I have so far because I didn"t want to twist off the forcing screws. Maybe I need to put a little more pressure on the wedge forcing screws. I did have the forcing screws out when I first started and cleaned them up as you suggested. If you have anymore ideas please let me know. I appreciate all your help. I'm not on the clock with this project but would like to get them moved at some point. Thanks.
Kevin Schmidt
12-07-2007 15:26:06
 Re: G/MAN: Moving Rear Wheels on 4020 in reply to Nellie 47, 12-05-2007 14:18:42
The best way I have ever figured out stuck wedges is to use a porta power or a hydraulic jack on the INSIDE of the wheel. First jack the wheel off the ground an inch so you can spin the tire. Place porta power against a roll bar, good fender mount (better if the fender mount has the flat side out for a better place to push off of) or cab mount with a good block inbetween. Make sure the wedge bolts that hold it tight are loose and the pusher bolts are tight. Push on the wheel CASTING, not the wedge, on the opposite side of the wheel casting the pusher bolts are pushing on. You can give it a pretty good amount of force without hurting anything. If it doesn"t pop at first, rotate and push against the same area as the pusher bolts. With the porta power tight, you should be able to get a little more out of the bolts. Then rotate back to the first spot and try again. I have never had this not work well, even on rusted up louisiana tractor that worked on a fish farm (really, really rusty). As a bonus, you don"t have to beat the crap out of your axle like the Deere dealers think you need to do.
Also, if you have ever snapped an axle and wheel off the back of the tractor, it is also a bear to get the broked axle off. Loosen the bolts up and we used a hammer until 2 of us were shot. We finally got the perfect tool, a bobcat with a concrete breaker. lay the tire on the ground, probably is anyway, and a few taps on the end of the axle it will shoot right out.
Hope that helps someone. I had bought a lot of wedges to replace all the broken ones before I used these 2 tricks
JMS/.MN
12-05-2007 17:59:21
Years ago a JD tech told me to whang on the axle with a bfh, like a 10-16 pound maul. Made no sense to me- I wasn"t trying to loosen the axle! It only transfers force to the inside of the tractor, does not separate the axle from the hub. You can look back in the archives for a description of a tool I made years ago to loosen the wedge. Or.. continue reading! Find a pipe that fits over the axle, about the same size. Cut half of one end at a 45 degree angle- that"s the hard part to describe- like the lower half of one end, at a 45 degree angle. ie, the top half of the far end is not cut,, but the lower half is. Weld a plate on the other end. Slip the pipe over the axle, when the movable wedge is at the top, so the pipe fits against that wedge, and whang the heck out of it- You are beating against the wedge you want to move!!
Dean Barker
12-05-2007 20:08:43
 Re: G/MAN: Moving Rear Wheels on 4020 in reply to JMS/.MN, 12-05-2007 17:59:21
I made a tool like this for my 4320's; really works. I had taken my first 4320 to the dealer to move one of the wheels; it came back with the wheel moved, one rough axle bearing, and the end of the axle all beat up. Can you take a picture of the tool that you made and post it? I'm not able to post pictures yet.
JMS/.MN
12-06-2007 09:32:04
 Re: G/MAN: Moving Rear Wheels on 4020 in reply to Dean Barker, 12-05-2007 20:08:43
Same thing as what wilamayb (below) did- but he cut his differently- he describes it well. Two ways to get the same result. Turn the wheel so the wedge you want to impact is at the top- Slip the pipe over the axle, will stay in place if you"re working alone. Can also tarp strap it to the wheel so it doesn"t wander.
ben brown
12-05-2007 16:40:44
had a 4440 that wheel had never been moved had the full cast centers. both ratch frozen one froce screw broken on one hub. i took all the wedge bolts out from the inter wedge. then the bolts from the outer wedge. 34 inch impack on force bolts. then from the in side i put a ten ton porta power on the cast center to the final drive housing. put tension on bolts and porta power big hammer hit the end of axle lots good word sweat but got them loes have done it that way sever time on older deere tractors. think next time i find some younger guy to work the big hammer though.
RobMD
12-05-2007 16:32:54
I have pulled a plow with all the bolts out of the wedges in a slower gear, with someone on the lawn mower keeping an eye on it. IT broke free after a football field length of stomping on the throttle a little bit.
Only problem was, it was a semi-muddy field that we had to work in with jacking it up and fixing the wheel. It worked, though!
RobMD
12-05-2007 16:48:29
 Re: G/MAN: Moving Rear Wheels on 4020 in reply to RobMD, 12-05-2007 16:32:54
Should mention that nobody I ever talked to believed me, but it really did work.
wilamayb
12-05-2007 15:11:22
So far as we know G/Man has been busy. I dont think he has been on in a while, so I'll try to tell you what I've found works without fail.
Things you need:
First put the wedge on the bottom and jack up the tractor.
get a piece of pipe that just fits over your axle and long enough to reach from the wheel wedge to the end of the axle with a few inches to spare. Weld a heavy piece of plate metal on one end of the pipe (this is your striking surface) On the other end of the pipe you should cut half of the diamater of the pipe so that it looks like a scoop. This will mate up to the wedge that needs moving.
Remove the three wedge bolts, then tighten the jackscrews tight, but realize that they will break if you torque them too much. Take the largest hammer you can find and whack the poo out of it. remember you cant hurt anything. It is fool proof. After a few good whacks check to make sure the jackscrews are still tight. You need the combination of tension and shock to get it to go.
If this does not work you just need to hit harder. If you think you are hitting too hard just hit a little harder.
It has never taken me more than 5 minutes to release one this way from the first hit till the last.
I would share a picture of my pipe, but I'm away from home with no picutres here. Sorry!
Kent Petersen
12-05-2007 16:45:50
 Re: G/MAN: Moving Rear Wheels on 4020 in reply to wilamayb, 12-05-2007 15:11:22
I also back out the cap screws on the other wedge as well. it is tapper to kent
