'37 B Motor Troubles Update! NEW PROBLEM!
Chuck McDonald
12-05-2007 13:10:53
Howdy,
Well I managed to get the motor apart and bring it to the machine shop to get the bushings pressed out. The mecanic then called me later on and said the new pushrod head bushings are too small! The old ones appear to be 3/4" and the new ones are only 5/8"!
The Part manual shows part # AB 1284R as being right for SN 39074. This part subs to B1290R now and that is what we ordered. Do these press fit or are they sealed some other way? Do I have the wrong parts?
Help!
Chuck
Earl - IL
12-05-2007 14:33:04
 Re: '37 B Motor Troubles Update! NEW PROBLEM! in reply to Chuck McDonald, 12-05-2007 13:10:53
Chuck, With 3/4 = .750 5/8 = .625 The "B" tubes I have are # B1800 R They measure .7325 on the big end. I have built tractor pulling heads & in order to put high lift rockers on the unstyled "A" & "B" we put larger water tubes in the head.This let us shorten the push rod end of the rocker arm. I have also made the oversize tubes to save heads that has the casting hole messed up by driving the tube out with a driver bigger than the tube. Scoring the head to where new tubes will leak. Here in Illinois we have a lot of scale built up around the old tubes.If you have that take a torch & heat the scale & it will pop out giving clearance for the new tubes. hope this helps you. Earl In Illinois
Chuck McDonald
12-06-2007 11:20:59
 Re: '37 B Motor Troubles Update! NEW PROBLEM! in reply to Earl - IL, 12-05-2007 14:33:04
Earl,
Are they around the same length as the original tubes? If so, it sounds like that may be what has happened to my head some time in the past.
Thanks
Chuck
Earl - IL
12-06-2007 11:45:31
 Re: '37 B Motor Troubles Update! NEW PROBLEM! in reply to Chuck McDonald, 12-06-2007 11:20:59
The B1800R measure 4.163 length. I thought this was the correct tube for the unstyled "B" head. Earl
Chuck McDonald
12-06-2007 12:26:29
 Re: '37 B Motor Troubles Update! NEW PROBLEM! in reply to Earl - IL, 12-06-2007 11:45:31
Well,
I got a look at a parts book from another member (i have my own but i think its at my folk's house!) and it said Part # AB 1284R was for B's up to SN #96000 or something. Mine is 39074. Anywho, it subs to B1290R now and that is what I ordered. Sounds like your part number should be what it really needs though!
Chuck
Chuck McDonald
12-05-2007 13:27:25
Frank,
The SN # is 39074.
I am unsure on the head #, but according to the parts book, it should be the right one for that SN.
Chuck
F-I-T
12-05-2007 13:22:25
Chuck:
Just to help us help, what is your tractor S/N and the head casting number?
Frank
