50 A cooling system
Larry T
11-01-2003 11:13:41
What is the capacity of a 1950 "A" JD without a water pump and where is the drain plug on the engine? I have no manuals so need help, thanks.
dw
11-01-2003 18:28:02
 Re: 50 A cooling system in reply to Larry T, 11-01-2003 11:13:41
My I&T shop manual shows 8 1/2 gallon of coolant, for a late styled A John Deere.
F-I-T
11-01-2003 13:17:08
Larry:
The drain plug should be apparent under the cylinder head, just behind where the lower pipe comes from the radiator. Bear in mind that it could have been the victim of a replacement plug at sometime over the years. I've seen pipe nipples, square drive plugs, garden hose valves, etc.
On the capacity, I don't have that handy, but I'd guess somewhere between 6 to 7 gallons. We had a '48 on the farm, and I think that was about it. A 5 gallon bucket didn't seem to hold it, though I could be wrong.
Frank
