Farmhand on JD A,
kirk in ks,
12-04-2007 21:13:35
this JD A ive got has a farmhand on it and ive never fooled with one before, the older cables are they safe or should i just take the thing off nd sell it seperatly and avoid it as it loks like the cables are kinda corroded and i dont know if it will work it has the hyd tank on back but im weary of the cables and the slightly corroded pullys under the cables above the seat and lower down,
55 50
12-05-2007 09:36:57
 Re: Farmhand on JD A, in reply to kirk in ks,, 12-04-2007 21:13:35
Those cables don't do the main lifting, they just tilt the bucket or fork back and forth. Seems they are plenty strong for what they need to do. If you're really concerned you can always replace the cables with new. Those Farmhands were wonderful old machines in their day, but a bit big and clumsy. Could really build some BIG haystacks!!
tworow
12-05-2007 05:44:29
If the hydraulic pump still works, apply lots of used oil to the cables and go stack hay. The cables can always be held together with clamps as long as they don't hang up in a pulley.
kirk in ks,
12-05-2007 06:01:51
 Re: Farmhand on JD A, in reply to tworow, 12-05-2007 05:44:29
ohh ok cool ill do that thanks alot guy ok,
kirk,
