4010 PTO REMOVAL
Tim...Ok
12-04-2007 07:45:29
Is there a trick to removing the rear pto shaft on a 4010? got the big plate unbolted that has the alignment dowels on the back..it'll come out about 1/2" but thats all I can get it to move..got the IT manual but it's not much help..
thanks,
Tim
MSM
12-04-2007 09:29:00
 Re: 4010 PTO REMOVAL in reply to Tim...Ok, 12-04-2007 07:45:29
If you are trying to remove the shaft and bearing and quille/drawbar support,the tractor has to be split at the transmission-rear end housing in order to remove the snap ring and pto shifting mechanism. Then the shaft can be removed. While it's apart it will pay to replace the shifting pin for the pto as they become bent and weak. The I&T manual should outline the proceedure.
