Here are some CAV-DPA-Lucas pump diagrams
jdemaris
12-04-2007 07:01:13
The timing advance rarely goes all at once, it just gets weak. All it takes is to be low by 2 or 4 engine degrees and it will make smoke and cause skipping. For that, you could just loosen the entire pump and rotate it a little to add 2 or 4 degrees - about 1/16" to 1/8". This will add that advance throughout the entire range - so it might make it run better at high RPMs, but will also over-advance it when starting the tractor. But, just a few degrees may - more-or-less make it all work fine.
It makes no sense to buy an expensive CAV-DPA-Lucas pointer. You'd be better off using a timing light.
Here are some diagrams.
third party image
third party image
third party image
