4020 Hydraulic Pump Problems
TomNTex
12-04-2007 05:01:12
Dad has a 4020 that just started giving trouble with the hydraulics. All of a sudden he loses complete hydraulic power and nothing works. Sometimes it starts working again after killing the tractor and restarting. Other times it takes a couple of minutes and then starts up again. You can always hear the pump making a slight tappen sound sort of like rocker arms when the pump is working. When the pump is not working it makes no sound at all. Usually can only hear the engine. Once it starts up, you can hear the pump making a slight tapping noise. We drained the sump and checked filter and inlet screen. All seemed clean. Any suggestions.
This is a side console LP with syncro tranny.
Thanks
Tom
jamie ellington
12-04-2007 13:58:19
 Re: 4020 Hydraulic Pump Problems in reply to TomNTex, 12-04-2007 05:01:12
does this happen every time you leave the cluch pedal down for a few minutes?we had a 2520 that was very bad for that
jdemaris
12-04-2007 05:54:50
The hammering sound is probably the stroke-control-valve inside the hydraulic pump. It is the main wear-item in that pump. When it gets worn, it makes a hammering sound and often, does not seat and you then lose all hydraullics. When it just leaks a little, it makes the engine turn over hard and often burns up starter motors.
You can put a new one in without taking the pump out - I used to do a lot of them and always carried a few new ones in my service truck. In the 80s, the part cost $25. Probably closer to $100 now - but can't say I've checked.
TomNTex
12-04-2007 07:23:53
 Re: 4020 Hydraulic Pump Problems in reply to jdemaris, 12-04-2007 05:54:50
Hey jdemaris,
I remember having a look at the pump one time and thinking this had to be accessed from underneath. Does one have to remove the front axle to change out the stroke-control valve?
Thanks a bunch for sharing your knowledge.
Tom
jdemaris
12-04-2007 07:46:08
 Re: 4020 Hydraulic Pump Problems in reply to TomNTex, 12-04-2007 07:23:53
No. If you look underneath the pump you see the spot where the adjuster screw and jam nut is. It takes a hex-Allen drive and maybe a 1/2" jam nut (takes a 3/4' wrench) ? The adjuster puts spring pressure directly on the stroke-control-valve. The valve falls out when you remove adjuster stuff. Keep in mind, the valve is actually two pieces - a valve and a seat. The valve will fall out, the seat won't. The seat is held in pressure from a rubber o-ring that seals it against the housing. To get the seat out, you remove stuff opposite it on top of the pump - and reach through with a punch. That is, unless you can find a way to grab it from underneath and pull on it. I've gotten a few out that way.
If you go to buy new from Deere, it only comes as a set - with valve and seat. But, when fixing your own - sometimes you can just regrind the surface on the valve depending on how bad it is. Often the valve itself will have a dent in it, whereas the seat is more uniform and not as bad.
If someone knows what they're doing, they can take the old valve and seat out, and put a new setup in - in less than an hour.
