630 Power Steering Pump Seals
GlenT
12-03-2007 19:37:23
I am rebuilding the PS pump and have the article from the 2-Cylinder magazine from January-Febuary 2003. A statement is made 'Install the seals, two in the front and two in the back half of the pump housing, face to face. The lip of a seal always goes toward the fluid you want to keep in.'
I think I must be losing it, but the way I read it is the 'face to face' means the lips of the seals are facing out (away from eachother) and the other side of the seals are facing in (face to face). Or, should the lips both be facing toward the fluid in the pump (The lip of a seal always goes toward the fluid you want to keep in.)'
I rebuilt one for my 620 a few years ago and can't remember how I did it for sure but they are not leaking at all.
Thanks!
Mike M
12-03-2007 19:47:47
 Re: 630 Power Steering Pump Seals in reply to GlenT, 12-03-2007 19:37:23
Face to face and the lips to the outside. I think you have to seal the oil in and also keep air from getting sucked in. I use a socket that just fits in the housing and my hyd. press so I can feel them go in and keep it straight.
Bob
12-03-2007 20:46:12
 Re: 630 Power Steering Pump Seals in reply to Mike M, 12-03-2007 19:47:47
I agree. And, pack a little grease in the inside area, between the lips of the 2 seals to lube them a bit..
GlenT
12-04-2007 09:09:18
 Re: 630 Power Steering Pump Seals in reply to Bob, 12-03-2007 20:46:12
Thanks, I think that is how I did it on the 620 because I remember packing lots of grease between the seals.
F-I-T
12-05-2007 07:17:18
 Re: 630 Power Steering Pump Seals in reply to GlenT, 12-04-2007 09:09:18
third party image
Glen:
Here is an ancient sketch I made up that I think was posted here some years back. This is how I install them. As a schematic, it agrees with what you are thinking. I know it "looks" backwardss, but in this case you are sealing oil from going out and the fluid known as air from coming in.
