What are these pistons in my JD 70
andy r
12-03-2007 17:13:58
The pistons in my John Deere 70 gas show this number on the top: F - 2304 R From this number can anyone tell me anything about these pistons??? Standard? Oversize? John Deere? After market? Thank you. andy
buickanddeere
12-04-2007 16:24:15
 Re: What are these pistons in my JD 70 in reply to andy r, 12-03-2007 17:13:58
New grade 8 studs & nuts plus hardened washers. The old ones are stretched and will not clamp down the head without distortion/warping/insufficient pressure. Cranking the old ones down tighter won't work.
gpuller
12-04-2007 08:05:44
I would say your leak is coming from the cracked block. Have a 70 that was doing the same thing. Block was cracked on the face from a head bolt to the bore. That block was also sleeved in one cylinder. It would blow water out the exhaust if it sat. At first thought it too was a head gasket, replaced it and still the same deal. Ended up getting a different block.
JDBert
12-04-2007 06:52:40
I wouldn't worry about the sleeve- I'd say more then likely its the head gasket, clean it up torque it down (210lbs) and retorque after you run it a few times. I've got sleeves in both holes and they are holding fine.
third party image
bill mart
12-03-2007 17:32:05
parts book shows them to be standard diameter gas pistons. bill m.
andy r
12-03-2007 18:36:21
 Re: What are these pistons in my JD 70 in reply to bill mart, 12-03-2007 17:32:05
Thanks! This tractor seems to be sleeved on one cylinder. There is a crack on the face of the block and it appears to go back through the water jacket. I think the sleeve is the repair for the crack. The crack was not welded. I pulled the head to replace the head gasket as I thought it was seepy. Once in a while you could smell antifreeze upon startup. Tractor has good power and no smoke. Guys, what is your opinion? Try it one more time with a new head gasket?? Thanks, andy
Bus Driver
12-04-2007 04:59:23
 Re: What are these pistons in my JD 70 in reply to andy r, 12-03-2007 18:36:21
I have no experience with that engine. But assuming that the cooling system is not pressurized, all that is needed is to contain the coolant where it is supposed to be. At the ends of the sleeve, I would use the Permatex #2 (nonhardening) to fill the block crack outside the sleeve. Really pack it in there. Then install the head and run it.
