Help Identify a Disc Plow
OhioTractorGuy
12-03-2007 14:51:36
Looking to see if anyone had any ideas as to the make/model/uses of a disc plow mounted on the side of a John Deere 430 Standard Tractor. I bought the tractor more or less for the plow thinking I could make an attempt at restoring it and mounting on one of my other standards. . . It looks to be well enough made that I cannot imagine someone put this together in their shop/garage and mounts right up to the tractor perfectly. It mounts to the side of the bell housing, the right three point arm, at the back below the pto, and under the rear of the bell housing where the two clamps sometimes hold implements up. The three point raises/lowers the plow to desired height. Ive been told the tractor originally came from Lousiana. . . Part of me wonders if it was used for levee/ditches for the rice fields. I had never seen anything like it before and being the fan of the Dubuques that I am I wanted to give it a chance at not being scrap. Any help is greatly appreicated and I can try to provide other information/pictures if that will help. The plow does not have any casting/model numbers that I can see anywhere but it does have some old remnant green paint. Thanks as always, Dave
PS, Ive posted a picture of the tractor and the plow in the Tractor Photos section under "430 with disc plow"
johns48jdb
12-03-2007 17:05:28
 Re: Help Identify a Disc Plow in reply to OhioTractorGuy, 12-03-2007 14:51:36
ih cubs had a plow similar to that on them too. it amazes me to see some of the things you guys say your going to restore. if your going to restore that tractor let me wish you a lot of luck
OhioTractorGuy
12-03-2007 17:49:57
 Re: Help Identify a Disc Plow in reply to johns48jdb, 12-03-2007 17:05:28
I think the tractor is better left as a parts machine. . . Most of what you see in the picture is for sale. A good bit of sandblasting and a picture or two to find out what might be missing and this may be an easy restoration. . . compared to some of the other things Ive started with. Thanks for your thoughts.
wilamayb
12-03-2007 15:46:08
third party image
Here is your photo.
