1952B won't start
chadman
12-03-2007 11:54:47
thanks for all the good suggestions but still no go.so far I have replaced the following with new battery,cables,switch,points,condenser,gauges,gas,settlement bowl housing,and had the generator,starter rebuilt and retimed the tractor after having the govner housing off. I retimedby lining the dimpple mark on the gov. gear with the dimpple on the flywheel teeth with #1 cylinder(left side cylinder if sitting in the seat) at top dead center.is this right???
36 coupe
12-10-2007 03:13:55
 Re: 1952B won't start in reply to chadman, 12-03-2007 11:54:47
Make sure the spark is jumping the gap at the spark plug.If the spark is running up the nose of a fouled insulator the engine wont start.I keep a pair of plugs soaking in a covered jar of lacquer thinner.
Ron Taylor
12-04-2007 19:18:10
Was it on compression stroke when you set marks on the gears?If not you're 180 out & it will never run.
chadman
12-05-2007 02:43:49
 Re: 1952B won't start in reply to Ron Taylor, 12-04-2007 19:18:10
yes compression stroke
Mike M
12-03-2007 12:10:27
Well you only need 3 things to make them run. Fuel,compression,and spark (on or near time). TDC or close ? on these. Which one or combination are you missing ? -Spark NEEDS to jump at least 1/4" and be blue.
-- Time so that it occurs at TDC on compression stroke. Make sure it isn't on exhaust stroke ! Put a compression gauge in and test psi. Should be at cranking speed,choke OFF and throttle wide open. 75lbs for an all-fuel and 100-125 for a gas model is ideal.
--- Fuel if you have the gas on and the choke full shut it should soon flood enough in the cylinders to get the plugs wet and or shoot gas out the petcocks ( on block bottom )if you can't get any gas in the cyl. them take out a plug and squirt some in and see if it will pop and or fire indication good spark and compression.
Or if you for some reason (like having just unstuck it after a good oil soaking)you have excess oil or antifreeze in cylinders it will drowned out your spark plugs.
