NW: I have a 70D as well, the original from our farm. I rebuilt it a few years ago and one thing I have had difficulty with over the years in several of my 6 volt tractors, including the 70D, has been battery quality. It seems that since the 6 volt units are not produced very often, they make a once-in-a-while run and then they tend to sit on the shelf for an abnormally long period of time. I think they waste a bit of their projected life because of this shelf time. So, it could be your battery. I have been installing Optima 6V "Red Top" gel cells and they do not leak, are now into lasting more than double of a conventional wet battery, you can lay them down, mount them upside down, they don't spew acid vapors, nothing. They cost more than a lead acid battery, but you get 1,000 CCA out of a unit smaller than a battery and none of the headaches and twice the life. You might want to look into one of those, even though that little pony motor certainly does not need a lot of CCA's to get going and keep running. If you have one of those clamp-on battery voltage/load testers, the kind with the two short jumper cables and clamp, it could tell you if the battery is up to the task. If it cannot maintain voltage under a hard load test, it could be a goner. I bought a nice little tester like that on eBay a while ago for under $15.00, and I can't tell you how many times I have used it. It has pointed me toward problems other than the battery on more than one occasion. But here is a quick test that almost never fails to find a current drain for other than the battery. Remove either battery cable. Have all switches turned off. Now connect a light bulb rated at the battery voltage between the battery post and the loose cable. If there is a current drain, the bulb will glow. On a system in good repair, no current should be flowing, all switches off, and the lamp will not light. If it does glow, take a wire off one at a time until the light goes out. When it does, you have found the drain. Try that and post back. Frank
