'48 B wheels
C DC
12-03-2007 06:55:23
I spent time this weekend sliding the wheels out to the end of the axles to have more room to work on the tractor. The left side was not a problem. The right side, whew! You guys know what I mean!
I"m curious now though, if it was so hard to pull it out, how in the world to you put them back?
wayneh
12-03-2007 17:40:34
 Re: '48 B wheels in reply to C DC, 12-03-2007 06:55:23
C DC: I just took the wheels off of my 48 B. It was a bit strange, they would slide part way and then stop. So, I took the lug nuts off, and slid the wheel to the inside, and then I saw that the outer part of the spline was slightly deformed/marred, not letting the intter part of the wheel hub come off, so after ten minutes with a file on only the outer portion of each splines they slide on/off perfectly now.
Wayne
johns48jdb
12-03-2007 17:35:10
seems like there was a discussion on here along time ago about putting wax paper in between the collars and the rims to make it slide on ease and make it easier to move the next time. am i just dreaming this?
Kris A NC
12-03-2007 13:50:19
I thought my '36 was going to be a bear to move. I loosened the collar off of the hub and rigged up the bottle jack and the chain around the tire. Once pump and it was moving. I took the jack off and pulled and the wheel moved...with little effort. If the splines are not boogered and rusty they should move with little effort like said previously. I think this particular tractor had and easy life in the shed as I can move the wheels fine and there are a whole lot of other things that show little wear. Just my .02. If you get it cleaned up and greased up they should move with little effort on your part.
Kris A NC
gurneejoe
12-03-2007 08:43:06
I was wondering the same thing with our A but what I realized is that if you take the compression collar completely off, the splines in the hub are then tapered due to the hub being slotted and sprung out a bit. After a thorough cleaning of course, I started the collars onto the hubs observing the splines. Once they became parallel, the hubs and centers slid on almost effortlessly.
Mike M
12-03-2007 07:10:28
They should go easier since they have been moved and you can also clean up the axles with a wire wheel. If you have cast centers if you loop a chain through the holes and then around the axle housing if you get it equal as you turn the wheel (by hand) the chain winds up and draws it in.
C DC
12-03-2007 08:00:55
 Re: '48 B wheels in reply to Mike M, 12-03-2007 07:10:28
Ok, thanks Mike. I figured there would be a simple way to do it.
thanks again.
