620 oil filter
Bobnc
12-02-2007 16:57:52
I just got a John Deere 620, gas, 1957. Went to change the oil filter and notice that the stud that the filter cap attached to is loos. In other words it spins. Doesnt appear to be attached to the oil filter top. Does anyone have any experience with this and possible causes and solutions.
JD hauler
12-02-2007 21:15:35
 Re: 620 oil filter in reply to Bobnc, 12-02-2007 16:57:52
Most likely the filter head is broken and that is why its loose, if your lucky, the canister wont be crushed too badly and wil still be usable, just bolt on a new top casting on the top of the canister and reattach the oil lines, if you have to replace the cannister, enjoy, stock up on lots of bandaids and get some sturdy rough cut oak to get the new one in, I did one on a JD A a few years back and I actually lifted the tractor off the ground before having the new canniste fully seated, it was fine, but they are very very tight going in.
Mike M
12-03-2007 04:45:18
 Re: 620 oil filter in reply to JD hauler, 12-02-2007 21:15:35
Those go in from the inside and go down into the case. You must be thinking of when you removed it of lifting the tractor up ? Easy to draw into place with some steel plates and some all thread.
F-I-T
12-02-2007 20:24:37
third party image
It attaches to the filter head body, and if it is spinning, typically, someone over tightened it, crushed the top of the can, and/or broke the casting so a chunk of it is turning up above. Or it is simply stripped. Either way, you'll have to go at it from above. Check that the top of the can is not distorted as this can lead to low oil pressure as oil escapes the gap between the body and the can top.
Frank
DJD-Man
12-03-2007 07:14:17
 Re: 620 oil filter in reply to F-I-T, 12-02-2007 20:24:37
Thanks Frank.
DJD-Man
12-02-2007 19:26:56
Screws up to a threaded post and keeps the cap and filter tight. Is this what your asking? Do you have manuals? Tighten it up or pull apart and look. Something seem missing or just need to be tightened? Parts book.
