820/830 electric starter
toolz
12-02-2007 16:27:17
I've had a few discussions here about my electric start 820, and all responses were greatly appreciated. The majority seemed to think that a semi starter, 42MT, 50MT, etc would bolt up to the factory 830 bracket on my tractor. One guy said it wouldn't. He was right- the bolt pattern is different. I tried to bolt up a nice new 42MT today, and it wouldn't come close.
Please let me know who sells a reasonably priced 12 (preferred) or 24 volt starter, and I will buy it. Thanks again-- Kevin
buickanddeere
12-02-2007 17:14:15
 Re: 820/830 electric starter in reply to toolz, 12-02-2007 16:27:17
The starter is the starter. The nose & pinion gear are swappable for dozens of applications, angles, gear pitch, gear ratio etc.
Lodemia2
12-02-2007 16:57:37
You need to get an adapter for the starter. I just updated my 730 DE with the newer style starter and the repair shop got it for me. If you need I could possibly find out who their supplier is.
toolz
12-02-2007 17:21:36
 Re: 820/830 electric starter in reply to Lodemia2, 12-02-2007 16:57:37
I will discuss the nose options with the elec. shop in the morning.
I don't quite understand the adapter option- if the starter is set back any farther, it won't mesh properly with the ring gear. Also, the mounting ears hit the 830 bracket so it wouldn't go in the hole.
Thanks again- Kevin
buickanddeere
12-04-2007 16:36:29
 Re: 820/830 electric starter, easy electric swap in reply to toolz, 12-02-2007 17:21:36
The entire starter snout is a separate and swappable piece bolted to the starter motor. Pinion gear & bendix are just as swappable too. This is another example of how so many people think an electric conversion is easier, quicker and cheaper than cleaning up and tuning a starting engine. Ain't so.
toolz
12-04-2007 18:50:42
 Re: 820/830 electric starter, easy electric swap in reply to buickanddeere, 12-04-2007 16:36:29
buickanddeere- This is NOT "another example of how so many people think....". You have been reading my posts- this tractor was set up for electric start when I bought it. As I said before, I don't have a pony motor, or anything related to it. I have found two companies that provide starters for this application in 12 or 24 volt for $200-250. If my local shop cannot fix me up, I will order one, and the tractor will start just fine. If an 830ES starts, so will this one. I appreciate everyone's help, including yours, but the negative comments don't work for me.
buickanddeere
12-04-2007 19:46:24
 Re: 820/830 electric starter, easy electric swap in reply to toolz, 12-04-2007 18:50:42
The negative wasn't directed at you. It was to point out to those tempted by starting engine to electric conversions. That something that looks so simple can get expensive and time consuming in a hurry. We all know of electric conversions that didn't pan out as planned. They are either warm weather only, tow chain only or have to be charged via 120VAC at the shop. Your project is just a starter swap and it's had it's moments. Did you go with 12 or 24V? Is the starter a MT42 or something else? You need the equivalent starting power for a 944cu" four cylinder diesel. Or a 1416 cu" six cylinder.
