4020/148 loader problem
New-Tex
12-02-2007 16:17:53
Got a 148 loader on a 4020. Sometimes the loader will go all the way up and sometimes it only goes up half way. Only drift down. Going up it goes at speed. Crud or air in the SCVs? Any thoughts on this?
Tx Jim
12-05-2007 04:57:22
 Re: 4020/148 loader problem in reply to DJR, 12-02-2007 16:17:53
Sometimes the plug-in tips get worn and then the balls don't unseat correctly. You might try new tips. Tx Jim
ET
12-03-2007 06:44:20
 Re: 4020/148 loader problem in reply to New-Tex, 12-02-2007 16:17:53
Try putting the tractor in newtral or park and let the clutch out. If everything works ok like this the problem is that the charge pump does not run when you hold the clutch down and you are running out of oil to the main pump. The loader can be plumbed in to work better by not hooking into the rear outlets.
matthies
12-02-2007 19:26:51
If you're running off of the scv's try changing the hoses from one box to the other. You might have a cylinder packing going bad and restricting the flow and causing odd functioning. Does the bucket operate ok? Or you might have problems with the valve itself. Is the oil level full? Remove the hoses from the couplers and look at the ends and look to see if any of the packing material is stuck in either end. Good luck
New-Tex
12-03-2007 06:43:55
 Re: 4020/148 loader problem in reply to matthies, 12-02-2007 19:26:51
thanks for the reply, Matthies. Yes the bucket works ok and the oil level is ok to. So the problem is unique to that one side of the system.
I have been putting off messing with it. Its a pain when moving the big round bales and the front end only goes up half way. Have to lay the round feeder on the side to get the bale in and afterwards pull it upright with the tractor.
matthies
12-03-2007 20:55:52
 Re: 4020/148 loader problem in reply to New-Tex, 12-03-2007 06:43:55
Please post back when you get time to work with it. chris
New-Tex
12-04-2007 16:25:11
 Re: 4020/148 loader problem in reply to matthies, 12-03-2007 20:55:52
Well, last night I disconnected the hoses from the quick disconnects at the back of the tractor and cleaned out both female and male connectors. There was a small amount of crud, but, it did not seem that it would be enough for those symptoms. Maybe there was a seating problem?After re-attaching and locking in to place all seems to work well. Keep my fingers crossed that it will continue to work. Have to put out another of the large round bales tommorow.
NewTex
