440 IC cylinder head
Larry H
12-02-2007 15:47:28
Looking for a cylinder head and a exhaust mainfold for a John deere 440 IC Serial number : 448276 its a total basket case that was torn apart 18 years ago and left out in the rain trying to bring it back but head is cracked. Thanks Larry
cskent
12-02-2007 18:04:07
 Re: 440 IC cylinder head in reply to Larry H, 12-02-2007 15:47:28
Hi, you better give more info if you want a answer, as far as I know at least 2 engines were in these. Maybe casting numbers if you can find them.
Larry H
12-02-2007 19:43:51
 Re: 440 IC cylinder head in reply to cskent, 12-02-2007 18:04:07
You are so right this is the gas engine with the high compression head as the serial number is past the 448001. Good catch thank you. Larry
