Good Evening Mr. Hall, There seem to be some electrical conflicts in what youre telling us. First, if BOTH batteries have their negatives tied to the frame and the positives go to the starter as you say, they are in parallell and NOT series and you just have 12 volts instead of 24 as a series connection would be. When you say both positive cables go to the starter solenoid, do they BOTH hook to the same post on the solenoid (2 cables in paralell) (like a 12 volt solenoid) or does the solenoid have 2 separate big posts and a cable hooks to each (like the 2 wire 24 volt solenoids were) The 24 volt 2 battery systems have the batteries in series with the + of one and the - of the other tied and bonded to frame ground, and the other + and - cables to the 2 post solenoid to power a 2 wire 24 volt isolated from ground starter. Next you say youre sure its a 24 volt starter??? but a 24 volt starter with only 12 volts applied doesnt work very well. Since you have two twelve volt batteries in parallel, my guess is you have a 12 volt negative ground alternator system. Some 12 volt negative ground alternators (like the GM 10 SI for example) have 3 wires to them and they may be internally regulated. Some people who had 24 volt systems converted over to 12 volts by re connectign the batteries in parallell, replacign the starter with a 12 volt, and using a 12 volt alternator of some kind. Take a look at the 2 cables to the solenoid and see if they go to one or 2 separate posts?? be sure both batteries have the - to frame as you said?? measure any voltage across the 2 cables at the solenoid and from each to ground and that will DEFINITELY tell you what you have (if its 24 across those cable ends the batteries CANT BOTH have - to frame, and if its 12 from either to ground, you have a 12 volt parallel system as I suspect) and let me know how well she cranks, cuz if it cranks well at 12 volts I doubt its a 24 volt starter. Post back or e mail [email protected] with your results and any more questions. Good Luck n God Bless John T
