JD 1010 diesel utility
Ron Pruitt
12-01-2007 19:46:20
Can anyone tell me if there is a way to determine year model if the serial tag is missing. I got a 1010 Diesel Utility today. I belive that is what it is anyway. It has the round adjustable front axle and the shifter in on the dash instead of the tranny. The photos I have looked at lead me to believe it is an early 1010 Utility. I can send photos to anyone that can help. I may sell it or part it out. If you need anything let me know. [email protected]
buickanddeere
12-02-2007 09:13:09
 Re: JD 1010 diesel utility in reply to Ron Pruitt, 12-01-2007 19:46:20
The dash masher transmission shifter was used from 10001-22123. The four bolt center frame/torque tube was used on industrials from 10001-42,000. Ags from 10001-31,000. The ag tractors went to a seven bolt trans cases relieved for the HD r&p from serial number 31,001. There was a run of industrial trans cases with the four bolt front but with the relief for the HD ring & pinion gears used from 31,001 until 42,000. The engine seen changes to the injection system at 31,001 and pretty much everything else at 31,000 and 42,000. Some engine gear covers changed at 16156.The engine oil pump was tinkered with at 26697,25941,25942,29818. The speed controls, engine shut off linkages at were revamped at 20735,31,000,35032,42,001. The export tractors and perhaps optional on domestics was an upgraded fuel filtering system. Rear pto versions are too many to list taking nine pages in the parts book. If you can find a donor 1010 the post 31,001 uses a slower ratio final drive which is a good idea. Power steering lines were re-routed at 22825.The power steering pump was changed at 24695. The brakes had a few changes at 21833 and 31,001. With the parts book it will be possible to narrow the tractor's serial number to a fairly narrow range. You are going to need the parts books anyways to find what can be salvaged off models 420,430, ag 1010 and both the ag and industrial 2010. I wouldn't part out an uncommon unit such as this.
Ron Pruitt
12-02-2007 11:46:12
 Re: JD 1010 diesel utility in reply to buickanddeere, 12-02-2007 09:13:09
Thanks for all the info. I posted some photos in the help identify section and can send more if you would like to see them.
Ron
buickanddeere
12-02-2007 12:19:31
 Re: JD 1010 diesel utility in reply to Ron Pruitt, 12-02-2007 11:46:12
The sheet metal is where? Without out it I wouldn't even bother. Somehow I had the idea going the tractor was an industrial rather than an ag unit.
Ron Pruitt
12-02-2007 13:26:37
 Re: JD 1010 diesel utility in reply to buickanddeere, 12-02-2007 12:19:31
I have the hood and one of the side panels. The grill and the side panels in the front are gone.
Ron
4020LP
12-01-2007 20:21:03
It's a '61 or a '62 if the shifter is on the dash. If the block has ever been in the hot tank, that was the end of the serial number tag. However, there is an engine number stamped the block near the top of the deck, and through a JD dealer, the serial number can be traced. There were only 353 of the 1010 Diesel Utility tractors made, which is one of the rarest 1010's, so think twice about parting it out.
Ron Pruitt
12-02-2007 06:43:02
 Re: JD 1010 diesel utility in reply to 4020LP, 12-01-2007 20:21:03
4020Lp,
Thanks for the info. I placed some photos in the help identify section if you want to take a look. I have a friend that has a 1010 diesel and it is nothing like this one.
