DLTX Carburetor - Problem Solved!!!!!
Pappy
12-01-2007 14:10:58
Cleaned rusty DLTX71 carburetor. All orifices cleaned, new float etc. Tractor still ran way too rich. Plugs got all sooted up and some black smoke from exhaust. Readjusted needle valves, no change. Got to thinking, when closing the needle valves, are they bottoming out in the seat, or are the bottoming out in the rusty threads?? Got a 1/4" X 40 tap and cleaned the needle valve threads. Yep---that"s the problem. Blew them out and re-adjusted the needle valves. Perfect!!!! Ran it about 1 hour and the plugs were clean with a white tip.
Joe Anderson
12-06-2007 16:31:27
 Re: DLTX Carburetor - Problem Solved!!!!! in reply to Pappy, 12-01-2007 14:10:58
I had nearly the same problem, the threads were ok but the needle on the idle side was pushed up into the top portion of the adjustment handle. I used a pair of pliers and pulled and twisted the needle out almost a quarter of an inch.
RobMD
12-01-2007 15:46:51
wow, never thought of that. I knew my idle and load screws were "crinkly" going in. I now know what that is, thank you for your contribution!
Bob
12-01-2007 14:56:50
 That's a GREAT tip... in reply to Pappy, 12-01-2007 14:10:58
That's a GREAT tip for working with these carburetors.
