Hi-output coil for Wico mags
Sam F.
11-30-2007 17:06:16
Where can I get hi-output coils for WICO C and X magnetos ???? Thanks
jd b puller
12-01-2007 05:15:52
 Re: Hi-output coil for Wico mags in reply to Sam F., 11-30-2007 17:06:16
Sam, I had my mag rebuilt several years back. I told the old timer, I wanted it "hot enough to kill a dog". He grinned and put something in there out of a snowmobile. Very nice. I"ll have to see if I can figure out what part number it is. I had an unfortunate incident after that, which damaged the bearing in the mag. I wasn"t sure how to fix it to I took it to an old timer that worked on mags. When he tested it, he just kept saying "Jeepers, what"s in that thing?" as it was arcing almost an inch on his test machine. It"s a Wico X.
buickanddeere
11-30-2007 21:05:14
Making certain the magnets are up to factory strength or better is required. You can super coil a mag all you want. However if the magnetic field, therefore primary current and therefore flux density isn't there. There will be only a weak spark.
Duane Larson
11-30-2007 19:29:39
Sam F.,
I'm not aware of any hi-output coils for the Wico C magnetos, only for the XH. They are available from www.robertscarbrepair.com on line, or you might call Mark's Magneto at 860-537-0376. I don't use them too often as I haven't convinced myself they are worth the added cost.
Will P
11-30-2007 20:16:07
 Re: Hi-output coil for Wico mags in reply to Duane Larson, 11-30-2007 19:29:39
Duane, why hasn"t anyone made a high output coil for the C? I know the X was better. But there are many C"s out there too. Got one on my A, and B.
Thanks,
Will
Duane Larson
11-30-2007 20:46:35
 Re: Hi-output coil for Wico mags in reply to Will P, 11-30-2007 20:16:07
Will,
Well, I can only conjecture, but my guess would be the technology and numbers involved. I think the replacement coils for the C are "hand wound" in the sense that they are wound one at a time on a coil winder with a person watching the process, and must be "dipped" and baked, and .... .
The replacement coils for the XH (I think) are made by coil companies in an automated process which takes more engineering and was developed in the mid 50's for the X5700B coil, which was the first to be encased in plastic. The X series magneto is still in production so requires coils for both new and replacement purposes, hence higher sales. I think the step to do this for the C magneto was never taken - the argument being that if you want a hotter spark, use the X series, which has a stronger magnet, an outboard bearing (as opposed to bushings), etc.
FWIW, the Wico X series magneto replaced the C series in July 1946 but was not adopted immediately by Deere.
Will P
12-01-2007 07:21:36
 Re: Hi-output coil for Wico mags in reply to Duane Larson, 11-30-2007 20:46:35
Thanks for the info. The C mags fire my allfuel B and A just fine. So they will stay for now. But I can tell you, the C mag on my B would not fire my G with high comp pistons. Ended up with a Delco dizzy. Now that works!!!
Thanks!!!!!
Sam F.
11-30-2007 19:33:59
Duane: Do you sell the regular coils for both, X and C ??? SAM
Duane Larson
11-30-2007 19:44:53
 Re: Hi-output coil for Wico mags in reply to Sam F., 11-30-2007 19:33:59
Sam,
Since you asked, yes. Contact me off-line at [email protected] for info. I'm tied up until tomorrow evening.
John T
11-30-2007 19:28:12
Roberts Carb or probably Duane Larson or Magneeders n about any mag rebuild shops has em for the Wico X but Im unsure if they are made for the C's.
John T
