4020 and 148 loader
Nylon4020
11-30-2007 15:26:34
http://www.kodakgallery.com/Slideshow.jsp?&mode=fromsite&collid=13490118115.73165243215.1196463781802&conn_speed=1
Copy and past this link in browser address to view the pics. Dont know how to make a click link in the text. Tried posting in optional link url box....will see what happens.
I managed to get my 148 loader remounted before it snowed and before temps have not been above 5 degrees for a week. Anyway I had it sandblasted and it is painted. It had been hit hard before I got it. I had it welded and got it pretty straight. Certainly good enough for what I do with it. It lays nice and flat with a new cutting edge on it. Took a few pics. Tractor is in various state of painted. Hood , dash , sidescreens are painted. I do small sections since I am taking everything down to bare metal. I know a couple of shots look like I am just spraying over rust. Not the case at all. Just working my way around.
I posted a couple of photos of my quick couplers and joystick setup. For those interested in joystick and 4020. I pulled hydro from the 3 point line close to the back because it was easier to route hose. Hydro dump does not go to filter cover. I put a T in right close to the screen and dump there. I must say, it works very very well. Want to say thanks to geraldj and another fellow who e mailed photos of their joystick setups.
Also have a photo of the weep holes with the halos around them. Hoping someone would comment on the severity. I have no water in the oil at all so thinking upper o rings must be deteriorating or the small amount of water getting to oil is vaporizing? no lose of antifreeze so must be at the early stage of deterioration.
Also a couple of pics of 790 with 419 loader and 60" mowerdeck.
JMS/.MN
12-01-2007 17:32:31
 Re: 4020 and 148 loader in reply to Nylon4020, 11-30-2007 15:26:34
I"ve followed your posts about rebuilding the tractor and loader, and you did a nice job on each. FYI....a couple of points. First- with your 4020, you have four engine mounting bolts on each side, at the rear of the engine, compared to two on the 3020. That was a problem with the 3020 that I hope you do not have on the 4020. They break off, and many had to redrill, tap larger. You can do that once- then you buy a new engine block the next time the bolts break and the engine is loose in the frame. Second point- go into archives..... a few years ago I posted pix to Gary in SE TX, regarding the loader frame mods I made 20+ years ago, after breaking the 2x2 side frames, then the motor mount bolts. Almost every 148 loader I"ve seen on a 3020, the 2x2 is broken and welded. My mod not only puts the frame and the load to the rear axle, it also provides a handy step on each side of the tractor. And I have not broken anything since on the frame or the engine.
Nylon4020
12-01-2007 21:24:33
 Re: 4020 and 148 loader in reply to JMS/.MN, 12-01-2007 17:32:31
JMS,
I would be interested in transfering the load to the rear axles. I didn't think I could do it with the cab and ROP inside the cab mounted to axle. I did check my frame rail / engine bolts. They are very firm. This tractor was beat on by probably kids at a cannery. I am amazed it runs and works as well as it does. One thing about a tractor like this is that it always got worked on. Do you have any photos on your mod? I will do a search but I seem to have no luck getting a search to work on the archives.
John
Nylon4020
11-30-2007 17:03:51
 This link should ......does work! in reply to Nylon4020, 11-30-2007 15:26:34
Link
Copy and past address and click on the picture to start.
Nylon4020
11-30-2007 15:35:08
Crud neither link is working. I will try again.
