99 F-350 Stroker Injectors
Tony W
11-30-2007 08:53:14
I have a 99 350 with 7.3liter Powerstroke, and found out that I have one injector going out, will be pulling all 8 and have them check out. My question, Is there a good place you all recommend to buy new or rebuilt if I will be at that point, and have you heard of better preformance injectors? I know some will be posting to buy another brand of truck so have your fun! Any good in-put will be greatly appreciated.
jamie ellington
11-30-2007 17:10:46
 Re: 99 F-350 Stroker Injectors in reply to Tony W, 11-30-2007 08:53:14
are you sure its not a valve cover gasket problem?those things are bad for getting a bad connection or broken wire
Tony W
12-01-2007 10:21:07
 Re: 99 F-350 Stroker Injectors in reply to jamie ellington, 11-30-2007 17:10:46
Yes I put it on a scanner and it can out that Number 7 at fault on two tests, I had that valve cover problem on the 96 I used to have. Also the computer drive mod went out ($1000.) OUCH. Thanks for the ideas.
jamie ellington
12-01-2007 17:14:16
 Re: 99 F-350 Stroker Injectors in reply to Tony W, 12-01-2007 10:21:07
i bought a set of 60hp injectors from swamp deisel in nashville,tenn ,they worked great,good fuel mileage and power,about 1600 +your injectors,i started out with stock injector and a 125hp deoblo chip and a ballbearing turbo then went to the 60hp injectors with no chip and a ballbearing turbo(lot better setup}had just as much power+better mileage,my injector problem started with oil pressure problem
wilamayb
11-30-2007 09:10:57
You may be better off to take that truck to a mechanic that has a scanner that can check those injectors while still in the engine. The diesel repair shop is going to charge to check them. I would go for a set of aftermarket injectors if you are going to replace all of them. If you are going to replace one you may want to find a factory replacement or a least a replacement with the same specs as yours.
