Hey, toolz
David from Kans
11-29-2007 18:29:39
How is that problem on the 820 working out? Give us an update.
toolz
11-30-2007 01:17:53
 Re: Hey, toolz in reply to David from Kansas, 11-29-2007 18:29:39
Welllll, here's where we're at. I got the starter off, cleaned it up, and found the data plate. It is a 12 volt, but was hooked up to 24 volt. Delco number is 1114011, which is not in any current Delco cross reference book. It has only one good mounting lug, so I can't rebuild it. I compared it today to a new Delco 42MT, and it appears that the drive gear goes out about 1/2" farther than the new starter, retracted length is the same. A few guys have said that a 42MT or 50MT will work, but it looks like they would not fully engage with the ring gear. I would like to go 12 volt, but some have said that's a problem also, due to slower cranking speed. I certainly can buy a new proper starter for it, but at $500, it's a bit scary. I would like to figure out a commom starter that fits, 12 or 24 volt. I'm going to the electrical rebuild shop tomorrow, so we'll see what he has to say. I still haven't seen the starter from the 8400 series tractors, so I don't know if it will fit, but it sounds like a good choice if it will work. I also have a few feelers out to find a rebuildable starter off an 830. We'll see what turns up. Thanks again for all the help. Kevin
kendak
11-30-2007 16:11:05
 Re: Hey, toolz in reply to toolz, 11-30-2007 01:17:53
Toolz ;Talk to Mike at DB Electrical , 5359 Kingsport Hwy., Gray , TN. 37615...they supply the gear reduction starters used on "A" & "G" pulling tractors...phone #800-753-2242....part # we use is 410-52074...new not reman...cost $199 plus ship...www.db-starter-alternator.com...take care...Kent
Mike M
11-30-2007 11:03:56
The distance that drive goes out should be adjustable somewhat. I used to work on starters years ago and when I did mine from my 720 D I don't remember it being any different than the ones from all the semis we worked on it was just an older design. You basicly had 2 choices of drives by tooth count and the nose position was adjustable. Not quite so far back when working at the Navistar truck dealer I think they ran specials on starters for around $200-$250 check with some truck dealers.
55 50
11-30-2007 09:38:10
Some information that may be of use:
The John Deere Electrical Systems Service Manual, SM-2029 lists two 24 V cranking motors for electric start 2 cyl diesels. 1113801 and 1113830. Also says they were used on 720, 730, 830, and 840 models. No mention of 820 so I wonder if that is an error. HTH
wilamayb
11-30-2007 16:05:24
 Re: Hey, toolz in reply to 55 50, 11-30-2007 09:38:10
55 50
No, your research is correct. The 820 was never offered with electric start.
The 720D was only offered with electric start during black dash production.
toolz
11-30-2007 18:56:09
 Re: Hey, toolz in reply to wilamayb, 11-30-2007 16:05:24
Thanks for all the responses again. I measured the distance from the starter mounting pad to the outside of the ring gear this morning. It was 3", the same as a normal truck starter. It seems that the junk starter that came with the tractor was over-engaging, and there was evidence of that on the ring gear.
Went to see my friend that owns an auto-electrical shop today. I asked him to build me the the strongest 12 volt 42MT that he could, and picked it up this afternoon. He said "take it home and try it. If it doesn't satisfy you, we'll build a 24 volt". Great guy. I'll put it on tomorrow, and we'll see what it does. I still like the idea of the gear reduction starter, but we'll see how this goes. Thanks again- Kevin
kendak
12-01-2007 17:42:27
 Re: Hey, toolz in reply to toolz, 11-30-2007 18:56:09
Toolz ;I talked to a 820 puller today at the Tunica pulls that converted his 820 5yrs. ago he made the bracket [ looks factory]from 1/2 in. plate using 855 Cummins 12 volt starter [bought from truck salvage yard for $50 bucks] with [1] gp.27 battery mounted where pony was & [1] wire GM alt. & had no problems with this setup...can't understand why you would want to crank tractor when it gets cold anyway...when it gets cold here we put the tractors in the barn & go deer hunting... Kent
toolz
12-01-2007 18:01:02
 Re: Hey, toolz in reply to kendak, 12-01-2007 17:42:27
Kent- Thanks for the info. Sounds like my setup will work fine, since I'm using a new starter and 2 950cc batteries. My bracket is a factory 830ES part. I will definately not be using this tractor in the winter. I will be installing everything tomorrow, and the temp is supposed to be around 50, so it better start. I'll post back when I get done. Thanks again- Kevin
