float level
430carbu
11-29-2007 17:29:46
what is the float level of the 430 with the tsx 688 ?
Duane Larson
11-30-2007 19:56:11
 Re: float level in reply to 430carbu, 11-29-2007 17:29:46
430 carbu,
With the top half of the carb upside down so the float is resting against the needle, the distance from the top of the float to the cast iron body should be 1/4", or close to level with respect to the carb body. The more important measurement is the actual fuel level in the bowl - to measure this replace the bowl drain with a 1/8 NPT brass hose barb, and some plastic tubing of proper size to fit over the barb. Mount the carb, hold the plastic tube so the top is above the carb body gasket, and turn the fuel on. The fuel will rise in the plastic tube and when stabilized, indicate the fuel level in the bowl, which should be 5/8" below the body gasket.
430carbu
12-01-2007 16:36:39
 Re: float level in reply to Duane Larson, 11-30-2007 19:56:11
thanks for the info I will try it
