630 JD First Reduction Gear
Old Bob
11-29-2007 16:37:59
I have gear noise in my 630 when I drive it, maybe a whine. It is worse when going uphill or under a load, and almost non-existent when going down hill. A friend of mine at our Christmas parade said it was in the first reduction gear. Today I pulled the inspection cover off the bearing on the first reduction gear. This is directly behind the clutch. The bearing does not have any up and down play, but seems to have quiet a bit of side to side or in and out play. If I were to tighten the nut on the end of the shaft to where there was very little in and out play, could this help with my noise problem. I do not have a shop manual, only parts and operators manual. If anyone can help with this problem, please do so. Bob in Arkansas
Old Bob
11-30-2007 06:34:49
 Re: 630 JD First Reduction Gear in reply to Old Bob, 11-29-2007 16:37:59
Thanks for the input guys. Will put the suggestions in effect today.
machinery-man
11-30-2007 04:07:15
There is zero clearance in the tightening...you are tightning nut onto inner race and inside if up against the imput shaft. As long as there is not in and out movement, bearing okay this is all you can do...the noise comes from the large gear teeth being worn down flat as well as the drive gear. This is essence causing teeth to hit as a flat surface allowing a rack motion instead of a rolling motion if the crown were on the teeth. Not much you can do as a used gear and drive gear would also be worn unless you could get parts off a real low tractor. Go with heavier transmisson oil and add about 3 to 4 cans of stp...don't over fill. STP is about one of the best to keep coating on those gear teeth. Hope this helps...
430WLPG
11-29-2007 17:58:59
I had the same thing on my 630 and i replaced the bearing and the big brass bushing in the clutch pulley and that cut the noise at the least in half or more
