4020 value
Larry
02-01-2000 14:52:23
Friend has a 4020 diesel wide front powershift. 1968 I think, runs super powershift great 2 remotes ok rubber starts easily Good looking tractor that I have used many times What is the market on that tractor as I can buy it if I want. Thanks larry
Don
02-03-2000 09:17:57
 Re: 4020 value in reply to Larry, 02-01-2000 14:52:23
Jan. 29, 2000 North of Joy ,Ill. a 1964 4020 power shift, narrow front, 18.4-34 , 3pt dual outlet's sold at auction for $28000.00 . this tractor pulled a 6 bottom plow in clay hills for several years . It looked as good as new with excellant paint .
Greg H.
02-02-2000 11:35:41
Eight to twelve thousand is the going rate. You hardly ever see a diesel for less, but rarely you do see one for more. I have no personal experience owning a powershift. My father in law owned a 67, and he had alot of trouble with it. Ofcourse I couldn't even imagine the abuse it was put through. If the trasmission is good try to get it for 9000 or less, because once you start using it you will be spending some money on. But like everyone says parts arn't bad, and with a service manual, and a good tool set you can realy do alot. They are my favorite tractors. Come to think of it, I think I'll go home this eveing and fire mine up, and give my little boy a ride, or drag a log or two. Later, Greg H.
medfarm
02-01-2000 22:16:20
A son-in-law of deceased neighbor farmer has a excellant condition 4020 WFE manual shift with 18000 hours on the engine. I believe they are asking around $9000. In central California, they will probably sell it close to $9000. Regarding the discussion of IH vs. JD, I bleed old IH 1566 and 856 red, but I buy new John Deeres. Both were and still are excellant tractors. The 4020 will hold it`s value long after everything else.
twopop
02-01-2000 17:32:17
the 4020 in good shape goes for between 8 and 12000.00 dollars american.
Lee Smith
02-01-2000 19:17:14
 Re: Re: 4020 value in reply to twopop, 02-01-2000 17:32:17
Larry, twopop is right on the money. You can't go wrong for a good 4020. Parts availability is good and will continue to be so for many many years to come. Where else can you find an older tractor with good meaty horsepower, dependability, performance, and design for under 12000. You get what you pay for! Good Luck!
Braddy Creed
02-01-2000 17:09:57
larry,if you pay over $4,500.your halucinating!if it was an 1066 int.go for it!
DrCyKosis
02-01-2000 19:27:06
 Re: Re: 4020 value in reply to Braddy Creed, 02-01-2000 17:09:57
Brad Creeddy...
While I dont pretend to bleed green when cut and am a confessed fan of some of those other color tractors theres no reason to be trying to stir the pot. Thats not what we are here for and probably why different makes have different pages to cut down on all the "bench farming". Comments like yours might be more at home on the general "tractor talk" forum.
comprende amigo?
Braddy Creed
02-01-2000 17:12:20
but you all know international rules.you low lifes!
Lee Smith
02-01-2000 19:28:41
 Re: Re: Re: 4020 value in reply to Braddy Creed, 02-01-2000 17:12:20
so INT rules huh? Is that before asking permission from Case NewHolland or were you hallucinating about the days when the flag of INT waved in the breeze by itself.
Glad I am still a low life Jd man. all in good humor! ha-ha
