12v on 730 diesel
Elton Fancher
11-29-2007 06:13:46
Has anyone put a 12 volt starter on a 730 diesel and if so what type starter did you use? How well does it work? I would appreciate any advice.
buickanddeere
11-29-2007 21:48:19
 Re: 12v on 730 diesel in reply to Elton Fancher, 11-29-2007 06:13:46
What is on there now? A starting engine or a factory 24V system? Or somebodies tinkerized 12V system? The two cylinder diesels are tough to start because the engine coasts for 540 degrees then has to compress 1/2 of 376 cu inches twice in 180 degrees of rotation. A 376 cu" two cylinder is nearly as difficult to crank as a 1128cu "/18.5L six cylinder. Unless it's a properly built 42MT starter, two group 31 batteries and some very beefy cables/connections. It will be a warm day starter only on 12V. On 24V it will be a cool and warm day starter. Mike got his to work on 12V because he compromised on nothing electrical, the engine was in peak condition and he used an engine preheater in cool weather. A 12V 42MT is a six cylinder 400cu" starter. A 24V 42MT is a six cylinder 900cu" starter. A 50MT won't even physically fit onto the 730. A 12V 50MT for cool weather or 24V 50MT for winter is what a two cylinder diesel really requires.
730virgil
11-29-2007 19:02:17
i have been going through that mess as we speak
a friend of mine was going to change to 12 volts as generator is bad and needed starter worked on also. i found a place that rebuilds starters etc. they were going to rewind it to 12 volts but my 730 is early enough that it has old style starter. what is going to happen now i don't know as my fiend had knee surgery and it didn't go to good.
mjbrown
11-29-2007 13:26:29
A few years ago a man who posted on here a lot ,Mike Manley (now deceased) described how he did it. He claimed it worked well. I have tried it and it did not work worth a fig. I had the starter rewound for twelve volts and used two large batteries in parallel with large diameter cables and it just wouldn't quite spool the engine up fast enough decompressed to kick it over when the decompression pedal was let up. I then tried two eight volt batteries in series to get sixteen volts. That would work in the summer if the batteries were well charged but just barely. When the weather cooled it was a no go. I went back to twenty-four volts and it starts great. I probably spent upwards of $800 trying all this stuff. If you want to repeat it go for it.
55 50
11-29-2007 18:14:17
 Re: 12v on 730 diesel in reply to mjbrown, 11-29-2007 13:26:29
The fellows name was Mike Hanley. There is a nice memorial to him on the Memorial tab at the left here and down aways.
Tom43
11-29-2007 17:24:47
You are much better off fixing the 24 volt system.
