4030 hydraulics
buck valley far
11-28-2007 19:08:10
To Tx Jim, asked question some time ago about hydraulics jumping,and being eratic, your reply was to check hex shaft. did and found that about 18" in on shaft from rear of tractor about 1/4to1/2" spot was rounded off some what, I guess thats were shaft drives pump, is that correct??? If so easy fix and thanks very much for the advice
wilamayb
11-28-2007 19:35:23
 Re: 4030 hydraulics in reply to buck valley farmer, 11-28-2007 19:08:10
You are right.. All you have to do is to replace the shaft. I was the writer suggesting to check the strainer for the supply pump pickup. Its not too often that folks are as lucky as you. Usually by the time they figure out the hydraulics are not functioning as they should the pump shaft breaks in that instant, which means the tractor has to be split to fish out the pieces. You are a lucky duck this time.
TX Jim is the man!!! Think of all the money he saved you. LOL
