JD 2010 hydraulics problem
gregg7817
11-28-2007 17:29:21
Friend having problems hooking up 46A loader to 2010 utility. Hooked 2 spool valve under the dash near pump. Can"t get any of the 4 cylinders to cycle. 3 pt and power steering working ok. Could it be a pressure relief valve in the system or could the spool valve be bad? Doesn"t act like fluid getting to cylinders. Says it is a open system. I"m a farmall guy so not much help to him. Any help would be appreciated.
Dave Neale
11-28-2007 21:02:16
 Re: JD 2010 hydraulics problem in reply to gregg7817, 11-28-2007 17:29:21
I have a 1963 1010 RU with a 36A loader and power steering, 3 point, and no remotes. It came from the factory with the loader. It had factory top-of-hood mounted headlights, The pump is under the dash on top of the trany. Two pipe connections with disconnects come out the right side cowl for the loader. These were factory stamped with mounting holes and fasteners for the lines. I could take a photo of the set up, if it isn't snowing too hard tomorrow. Send me an email and I will send a jpg.
I know they had different pumps that could be ordered, so mine may not be the same as yours. Dave Neale Caledonia NY
mattd
11-28-2007 17:50:18
that is a closed center hyd system. make sure your spool valve is set up for that. i dont know a 2010 very well but there should be a 90 degree fitting by the brake pedals with a steel line going to the 3 pt. put your tee there this will pressurize your valve. drill a hole in the trans filter cap and thread it for a fitting and run your return here, this way the return from the loader is filtered
ben brown
11-28-2007 18:33:15
 Re: JD 2010 hydraulics problem in reply to mattd, 11-28-2007 17:50:18
2010 IS NOT CLOSED CENTER. it is open center. the remote mounts on top of the piroity valve under the dash. are you sure he is working the spool when moving the control lever.the engine should load if no hoe is hook to the remote when lever is moved. now are you sure you have enough pressure. i know that the 3 pt well rase if no wt. is on it and also power steering well work to some extent. if you trun thr steering wheel to stop you should here the engine load and relief valve open.
