Which Deere's are best for slow racing ?
THE SMOOTHED DE
11-28-2007 13:19:09
Just wondering which tractors are winning these races ? Farmalls , Case , others ? Any and all thoughts are welcome !
02XLT4X4
11-30-2007 06:13:44
 Re: Which Deere's are best for slow racing ? in reply to THE SMOOTHED DEERES, 11-28-2007 13:19:09
Our old 1950 A will crawl along, you can count each time the cylinder fires. The only thing really in its class that was a condender either a 60 or 620, they idle a little smoother because of the different carb so they would go a tad slower, but they don't show up that often. Usually the three slowest at the show are usually the A, a Case 800 w/ Case-o-Matic, and a IH Hydro (might be a 1206?).
JD8020
11-30-2007 04:32:50
The best mechanical drive I've seen is my 440ID with a Auburn trencher attachment. You have to set stakes to see it move Roger
John T
11-29-2007 05:25:40
In the Deere line its certainly NOT the older single barrel carb models, the duplex and esp the 20 and 30 series have some chance HOWEVER the tractors with high/low and hydraulic/hydrostatic types of trannys and 4 or 6 cylinder engines that can idle down extermely slow are awfully hard to beat.
John T
Texas Sand
11-28-2007 18:53:44
I've never seen a slow race, looks like fun. I've got an old Case with the Case-O-Matic trans, looks like it would be hard to beat, it has a torque converter, you can put it in gear, let off the clutch, hold the brakes a little and go slow as you want for a long time as long as you keep the RPM's low.
motorstuff
11-28-2007 18:03:55
I easily won a slow race with our JD 730. The slowest "red" tractor had reached the finish line as I got to the half way point. Our tractor has the very low 1st gear. Some of the 730's had the low first gear and some do not.
GeorgiaHayFarmer
11-28-2007 18:00:19
I've got an MT John Deere that is pretty slow...but then so is it's owner...
J Plunkett
11-28-2007 15:57:39
I have a 4700 compact utilty with a creeper trans first gear wide open is .1 mph. First ten gears are under 1 mph
Ken52M
11-28-2007 15:18:31
The few slow races that I have seen were all won by JD 60. most times, red tractors don't even try... geared too fast.
RobMD
11-28-2007 14:37:42
a hydrostatic tractor. Go along a half of an inch an hour if you'd like.
:D
jteddixon
11-28-2007 13:53:03
The Model M John Deere has one of the slowest 1st gear ground speeds I've ever seen. It only goes about 3/4 mph or so. Even slower at dead slow idle.
