Chooch, Keeping in mind that the casting number on F&H hubs are for the hub only, I have seen HC234A wheels with both 16" and 18" rims. The 16" version had p/n AC1062 and were available for the Model D from 124194-, and used on the GP and GPO from 229216-. The 18" version had p/n AD990R and was used on the D from ~10/33 to 159010.I have studied wheels quite extensively and have not found a Deere publication which provides F&H casting numbers. F&H hub castings were used for different wheels - a good example is the F&H HC177 rear wheel used on the unstyled B - it is the hub used for both round spoke rubber tires and flat spoke skeleton wheels. So, if you ordered a F&H HC177 wheel, what would you get.... F&H did assign their part numbers to wheels, and some of that information is available, particularly for rubber tired wheels, but is only useful for cataloging as the info is normally gone from the wheel. What I have been working on for several years is photographing and cataloging F&H wheels, and wheels used on Deere tractors, and correlating the part number with a casting number. So far I have over 240 wheels identified through the lettered series, and that does not include the vertical-engine tractors (L, M series). I have given seminars on wheels at the Gathering of the Green conferences (www.gatheringofthegreen.com) and will have a drop-in session on wheels at the next one in March 2008.
