Fan Shaft Tube, 1936 A
Larry Goetz
11-27-2007 19:51:47
The outer tube which houses the fan shaft is broken about halfway down the tube. Any ideas on how to fix this or where to find a replacement?
P Browning
11-28-2007 07:16:14
 Re: Fan Shaft Tube, 1936 A in reply to Larry Goetz, 11-27-2007 19:51:47
Larry I just sent you an email connecting you with Airparts, inc. Great bunch.
The reason I post, however, is a warning of general interest to all. I carried my old item to a fabricator/machinist for extraction of the old piece from the fanshaft forward bearing housing. They broke the casting! Needless to say with the critical nature of alignment of JD fan shafts and their mating issues with the governor, I then found a replacement from a junk yard. Be sure all care is taken so that the bearing housing casting is not damaged! I hesitate to try a fix one this one.
One other issue -- length of the tube determines overall fan shaft length. Be sure you measure and cut so as to end up where you started!(PatB)
